Anusha 1/10th scale bust, Pedro Fernandez Works
PaulinKendal
Paul
Kendal
Here's another bust from Pedro Fernandez. I had some difficulty excavating a sliver of supporting material underneath the lower part of the nose ring. The nose ring snapped, and I've glued it back together, rather inexpertly.
Her skin is pretty rough - I've been stuggling to get the right tone, while keeping her really dark - I'm hoping her skintones will contrast with much brighter coloured fabrics.
Very interesting subjects you come up with every time Paul (y) great work so far, have fun!
Great skin tones, just really excellent colouration. Very interesting sculpt as well. Just out of interest, what is the dot on her forehead?
Thanks all. I've attacked the skin tones again, trying to get a stronger contrast between light and shade. Very rough at the moment, with a LOT of violet in the shadows.
From straight ahead (if you ignore the roughness) she looks OK. But from thr shadowy side she looks a mess. I'm going to lighten that side a bit, and reduce the violet tones considerably, and see how we go.
I know she looks worse than she did before, but you don't make an omelette without breaking eggs.
It's called a bindi, Tim. It has lots of meanings and religious significance, but is also worn simply as a custom or fashion (maybe like a crucifix is, in other cultures? Or perhaps beauty spots?)
The dominant notion is that it represents the Third Eye, the seat of wisdom, and the point of concentration - when I'm painting and really focused, it's easy to sense the centre of my attention is radiating from exactly that spot.
Traditionally a bindi would've been applied by finger with pigment. A lot of effort can go into getting the bindi just so. Sometimes a coin with a hole would be used to apply a circle of wax paste in exactly the right position. Remove the coin, colour the wax dot with vermillion paste and it's done. Nowadays they're often stick-on dots.
Men wear bindis and other forehead markings, too. When I was in India last year, on one occasion, at a little wayside Hindu shrine, I had quite a bit of multicoloured paste applied to my forehead, including turmeric paste, which took several days to wash off!
I might add extra markings to this figure, a bit like this:
Very interesting to see you deal with the lighting effect Paul, seen some figures with this effect in a magazine once, very cool but takes a lot of skill to get it right. You're definitly on the right track, have fun 🕯️
Great stuff paul , I love to see figures like this and have really struggled with the faces on the few ive done ( albeit smaller , Airfix 54mm types) but I still want to give it a good go so have ended up with a couple of larger resin figures , I might be picking your brains in the near future ! Cheers tony
Cool. I thought it might be a bindi, but it seemed too “perfect” and three dimensional. Looking forward to this one though, you are great at eastern skin tones.
Hi Tony, I'd be delighted to help, if I possibly can. I've learned a huge amount from the good folks on here, especially that @Tim Marlow fella, so if I can pass any of that knowledge forward, I'll certainly do so.
You left me in the weeds ages ago Paul…..you show far more flair on these big busts than I ever did, and your technique is way beyond me now. I’m still pretty good on the little blokes though 😁
Yes paul , Tim is another member who’s expertise I’ll be needing
I disagree, Tim. The precision and clarity you achieve with the little chaps is something i just couldn't do, I'm sure. While you produce all sorts of different things to a very high standard, I've just improved by contentrating on one particular field, to the exclusion of all else.
But you're very kind, nonetheless!
