Water washable resin
Andy T
Sheffield
As some of you may know I've been pondering a resin printer for some time.
With their prices falling they are looking even more feasible, and the better availability of water washable resins makes it seem a much less chemical heavy pursuit than cleaning with IPA.
My question is, does anyone have much experience with such resins? The word on the street seems to be that they can be a bit more fragile, but given that I'd mostly be using it for model parts, and my son for miniatures, I can't see that being an issue.
It will be housed in our utility room (where the gaffer allows a little mess 😂 ) and I'll have a sink etc handy (no, I won't be washing it straight down the drain)
Currently on my radar is the Elegoo mars 5 ultra, plus a suitable cure station. Any advice on that particular model would be good to hear too.
Thanks in advance.
I've not yet used waterbased resin, but keep in mind it's still a toxic brew when you clean the models in water. It gives a false sense of safety imho. Probably fine for what you're planning to do with it though. Have fun
Thanks Steven, I hadn't thought about it that way.
I'm aware that it still needs treating carefully but I guess I'd naturally be even more cautious if other chemicals were involved.
I use nitrile gloves when using water washable resin. Not latex or the other one?! I have never tried "ordinary" resin so would be interested to hear a comparison from someone who has used both. I can say from personal experience the WW resin can warp very badly. I recently decided to use my Ender3 to print a small plaque with lettering instead of my resin printer. I knew the resin print was likely to warp and wondered how much filling etc a PLA print would take. I printed one plaque at 0.16 layer height and it came out perfect-ish. One or two small divots in some of the letters that were easy to fill. I now have a renewed respect for my Ender, but wonder how much better a new printer/resin setup could be.
Lee
Andy, I can heartily recommend the Elegoo Mars, although I have a much earlier version. I've never tried the water washable resin so I can't advise I'm afraid. I think probably the only benefit is that you don't have to buy IPA for cleaning.
Thanks for your insight Lee and Neil.
To be honest I thought WW resin would make life much easier, but the more I research, the more blurred the lines become. I'll be getting a wash & cure station anyway (either combined or separate, still undecided) so I might as well start with IPA cleaning until I get a bit of experience under my belt.
Thanks again for all of your replies. I'll start a topic once the printer arrives to document my initial fumblings 😁
Would be an interesting topic Andy. Many of the younger guys would find it good. Too old myself 😭
I probably am myself, but I'm lucky to still have a youth knocking around the house 😂
I reckon Thomas will use it 90% of the time, but it'll come in very handy for me at times.
One of his best mates is studying 3d modeling at Uni, so that side of things is covered too.
After lots of research I've pulled the trigger.
I've gone for ABS-like resin as it's supposed to be more flexible & durable, without sacrificing too much quality. Ideal for our needs I think.
Once Thomas has got it up & running I'll have him give his dad an idiots guide 😁
Plus one on a good thread for this. I’ve had more than a passing interest in this stuff for quite a while without really going for it…so it would be great to see how you get on with it. Home 3D printing seems to be the go to for a lot of miniatures these days….
I've never used the washer part of my washer/curer. The tank holds so much water I wouldn't be able to dispose of the waste. Instead I use warm soapy water from a small sqeeze the trigger spray bottle and various small brushes to carefully wash off excess resin, then rinse the part under a tap that has a spray function (all water is collected in a plastic bowl bought for the task). I then use a lilo inflator to blow as much water off the part as I can before it's put into the curer. I am still unsure as to how much time a curer should run, so it's a bit of an ongoing experiment (where I forget what I set it at the last time). If the part has areas that look as though they might have some uncured resin on them, I give the part a gentle scrub with a small brush dipped in IPA.
Lee
Thanks Lee. I ended up going for regular, IPA wash resin in the end.
I figured the water would still need treating like a hazardous material anyway so thought I might as well stick to IPA. I'm used to handling chemicals, we'll just have to see how much the boss complains about the odour! 😂
Lee
I always cure mine for the maximum 30 mins, sometimes more if I think it needs it.
I find the ABS-Like resin also needs a bit longer after curing to finally go rigid.
I'd still like to find a resin that isn't so prone to warping, although I haven't actually bothered investigating it ....
