Tirpitz with this and that, slow return for me
Me too lol! Just put a spare bit of wood deck on plastic card. Instructions say to varnish first.
The satin varnish seems to have done a good job of bringing out various shades of brown planks
Did make a start at the stern but overdid the bluey shadow. Must have left it dry too long so the remover didn't remove much. One to watch out for.
However the instructions, bugger all.
Good luck with the liquid pigment. I have an aircraft set that I simply didn’t get on with Bob. I found the remover stripped the underlying paint. Probably just me though. Looking very good otherwise though.
Hi Tim
So far ok, will see after its dried. But the lack of instructions is terrible.
Bob, I asked the AI how to use the set, this is what it replied, perhaps it can help you out? Goodluck
That set is actually pretty powerful—but the instructions assume you already know “weathering” techniques. I’ll translate it into a practical, step-by-step workflow, specifically for a wooden deck on a ship model.
🎥 Official demo (worth watching once)​
How to Use – Hulls & Wooden Decks Liquid Pigments
🧰 What you actually bought (in plain terms)​
Your Lifecolor set contains liquid pigments, not normal paint. Think of them like:
  • very thin washes / filters
  • adjustable stains you can remove or blend
Typical colors in your set:
  • Wooden Deck Darkener / Shadower → for wood tone variation
  • Dried Salt → streaks & weathering
  • Surface Shadower → panel lines & depth
  • Fouling Green → algae/grime (mostly hull)
  • Remover → this is key (lets you erase/blend everything)
They’re designed to be manipulated after application, not just painted on. (Chronos Engineering Tools)
🪵 HOW TO USE IT (simple workflow for a wooden deck)​
1. Prep (this is where most people mess up)​
  • Seal your deck with a clear satin or gloss coat
    • This is important → pigments flow better and don’t stain instantly
  • Let it dry fully
👉 If you skip this, the pigment will soak into wood and you lose control.
2. Apply the pigment (light and messy on purpose)​
Use a fine brush:
  • Dip into Wooden Deck Darkener or Shadower
  • Apply lightly:
    • along plank lines
    • random planks (not all!)
    • around details
Don’t try to be neat.
👉 You can:
3. Blend / remove (this is the real technique)​
Now take:
  • a clean brush slightly damp with water or Remover
Then:
  • soften the lines
  • wipe away excess
  • drag pigment along planks
This creates:
  • subtle shadows
  • natural wood variation
👉 Key idea:
You’re not painting—you’re editing the pigment after applying it.
4. Add variation (don’t overdo it)​
Repeat with:
  • darker tone → for deeper planks
  • lighter/dried salt → for faded areas
You can layer effects, but:
5. Lock it in​
When happy:
  • spray a clear coat (satin or matte)
Otherwise:
  • everything stays removable
🎯 Techniques that work especially well​
✔ Plank variation (most realistic look)​
  • randomly darken individual planks
  • blend edges softly
✔ Panel line shading​
  • run pigment into plank seams
  • clean excess → leaves subtle lines
✔ Filters (advanced but easy)​
  • apply a very thin coat over whole deck
  • wipe most of it off
    → creates a unified tone
⚠️ Common mistakes (avoid these)​
  • ❌ Applying on raw wood → stains instantly, no control
  • ❌ Using too much pigment → looks dirty instead of realistic
  • ❌ Not using the remover → that’s half the system
  • ❌ Trying to “paint cleanly” → this isn’t normal paint
🧠 Mental model (this helps a lot)​
Think of the process like this:
Apply messy → then sculpt it with removal
That’s why Lifecolor says it behaves a bit like oils—you can push it around after applying. (Chronos Engineering Tools)
👍 Quick beginner recipe (follow this exactly once)​
  1. Satin clear coat on deck
  2. Apply Wooden Deck Shadower along plank lines
  3. Wait ~1–2 minutes
  4. Blend with damp brush
  5. Randomly darken a few planks
  6. Seal with clear coat
That alone already looks realistic.
If you want, tell me:
  • what ship scale you’re working on
  • whether your deck is real wood veneer or plastic
I can give you a tailored technique (the approach changes quite a bit depending on that).
What I have done is to paint a separate plank either with the brown shadow or another with the bluey coloured darkener Also then mixed together, but of course randomly
Let it dry then using a brush remove using ( yes) remover. I have been almost dry brushing but next I'll load the brush more
Right tad more progress, added some random stained planks. Hopefully you can see them?
Biggest problem is getting the drying time right, not enough time and you take it all off or too long and it stays there!
Some of the deck has slightly lifted, so with the last wood deck to go on the bow, I'm adding a layer of watered PVA.
Careful--water & wood--not usually good.
Evening the pva will sit between the plastic deck and the adhesive on the wood deck. Seen a good few ship builders using it to stop the deck from rising. So I'll give it a whirl!
Afternoon all
Deck finished and tape removed. So test fitted some of the superstructure. The large front section was catching the pe AA splinter shields so a very carful trim with Xuron pe snips. One not to do again, must do more test fitting!
Next more priming and top coats
Finally coming to life and end in sight!
Evening still breathing !
Been experimenting with accelerator and not that happy.
However made up the collapsible bridges. For some reason found them a right pain. One fitted and left to set
Just incase folks don't know. German large warships had to navigate the Kiel canel to get access to the North sea, so to ensure the hull didn't hit the canel walls, they could unfold these bridges on both sides Are you still awake lol
I THINK SO BOB MATE ZZZZZZZZZ yawn lol well i dint know that boyo so ive learnt something today well done for informing us all yes fab job my freind are you goin to fit crew members ?
chrisb
chrisb
My pleasure Chris , hope the kip went well 😀
