Steve's Revell 1/48 Mosquito B Mk.IV
So I have been having a bit of a nightmare with this one chaps. Things were going reasonable well and I got the office internals all assembled. I used the kit provided seat belt decals.
Then the fun started I could not get the fuzz sides to join. A check online shows this is a common problem experienced by many with this kit.
So the hacking has begun which has resulted in many of the fitted delicate parts dropping off. Work is continuing but I am not a happy bunny.
Crikey 😮 that’s really disappointing, I hope you manage to sort it Steve 🤞
Geoff.
Good old Revell. Hope you can get the fit sorted without too much damage Steve, and that the rest of the build progresses without too much hassle
I bought this model shortly after returning to the hobby. When I looked into the box, I closed it up and put it away for a very long time. It did get built in the end, some years later.
Ouch, that is frustrating when you’ve got the office all sorted and then the fuselage looks like it was made for a different piece of kit.
Yes it is Neil. Broke a few pieces off whilst sanding down. Very annoying.
So I have finished sanding and managed to get a decent join at the front end of the fuzz. The join behind the seats is a different story. I cant get the parts to come together cleanly. I toyed with the idea of removing some plastic from the area that I have circled in order to get the front of the seam to join but if I do that it will affect the join of the remaining rear part of the fuzz.
So with that in mind I am cutting my losses and will resort to filler. At the moment I am gluing the fuzz together in two stages. I have glued and clamped the forward section in front of the seats first. Tomorrow I will join the rear section behind the seats, reinforce the seam internally and then fill , sand and rescribe where needed.
Next up some work on the wings. Flaps and ailerons were made up and the wing halves joined. No issues there.
Then I put the Merlins together. Each engine is made up of 7 separate parts. Again no major issues just some minor trimming to get a good fit.
Thats it for now. Thanks for checking in.
I have to say that this has not been a pleasant build experience. It started off well and then went downhill when it came to join the fuzz halves together. The fuzz comes in four pieces. There are two forward sections that come together to enclose the cockpit area and then you assemble the rear two sections and then bring the two completed sections together. Just a recap. The below picture shows the completed cockpit area and I have circled all the areas that I had to trim, on both sides, and sand to get the two halves to come together.
Below are the instructions that show the two halves coming together
So I now have this.
Just ended up with a small gap behind the cockpit area. I have reinforced the seam on the inside with some epoxy bandage and will be moving on now to tidying up the fuzz seams. One advantage of doing a Mossie being a wooden construction is the absence of panel lines. That will make cleaning up so much easier.
I have also assembled the rear tail wheel assembly which needed to be done before joining the rear fuzz halves together, and I have put some protection around the rear pitot static tube. There is more work to do on the tail wheel, seam removal etc.
The instructions now tell you to fit the wings but this is a bad idea. There is a ton of stuff to fit to the wings, engine mountings, engines, cowlings, undercarriage etc and the information on internet is that I should expect more fit issues particularly around engine cowlings/covers. So I am going to complete all the wing fittings and assemble the wings at the end. I could not however resist a dry fit just to keep my enthusiasm up. Hopefully the next part of the build will be more trouble free.
Sad to read about all the fitting issues Steve, great to see you keep on going nonetheless (y) :coffee: you'll figure it out - goodluck
I admire your perseverance. My Revell Huey still sits in the bin under my bench as a reminder.
Its not perseverance Neil I am just tight. I have lived in Yorkshire for so long that like any true Yorkshireman I refuse to bin something that I paid good money for. :)
That looks good Steve, I'm sure you will be able to deal with those seams etc. After the repairs and clean ups, you will have a great looking Mosquito
On a side not I didn't realise until now that the Mosquito had a Merlin V12 which had a 6 into 5 exhaust system. I have always assumed the Merlin had 6 pipes on each side. I thought the model was inaccurate but it is correct as the picture shows.
As the model comes with some half decent Merlins I have decided to open up the cowlings to expose them. I will leave the inner cowling complete on each wing but the outer cowling I have decided to remove. So out with the scriber tool and some careful cutting was done.. Below picture is of the area I am cutting away.
And this is what it left me with.
Next up I have started to assemble the wing cowlings and all the internal frame work for the engine support. This is done in stages with one side of the cowling being glued into position on the wing and then building up in stages all the internal components.
Note that the exhaust pipes on the closed cowling side need to be attached to the cowling prior to fitting the engine as if you glued them to the engine first you cannot insert the engine because of the curve on the exhaust manifold outlet/pipes.
This will now get sprayed up with the interior green before I can attach the undercarriage legs etc. I am glad I did not attach the wings to the fuzz until after the engine compartments and undercarriage were installed and built up as this has been very fiddly work so far.
Looking good Steve, good attention to detail. I had never noticed the number of stubs before. Turns out there were two configurations:
  • Single-stage Engines: Commonly found in earlier models, these engines had five exhaust outlets. The design choice was made to avoid heat interference with the aircraft's wooden structure and the nearby radiators.
  • Two-stage Engines: These engines, being longer, could accommodate six exhaust stubs without the same concerns, leading to improved performance.
So to recap. Because of the information contained on various reviews on the web highlighting the poor fit of the engine cowlings, in anticipation of much trimming, filling and sanding I have decided to build up the undercarriage and fit the cowlings before I fit the wings to the fuzz and not before as suggested by the instructions.
The undercarriage is quite complicated and the parts are very fragile. Sadly it wasnt long before I broke something. There are two main outer components to the undercarriage into which numerous small components are added. These pieces are as thin as small pins and break at the drop of a hat. They also dont fit very well and Part 85 was the first casualty.IMGP0013.webp
Below is the offending part next to a cocktail stick.
So I have moved forward by assembling the main outer struts and reinforcing them by gluing the wheels on. The micro surgery internal cross member parts will be trimmed and fitted at the end of the build. This has now allowed me to complete the assembly of the cowlings.
The fit is not brilliant so the filler is coming out. I will also fill and sand the main fuzz seam lines before bringing the wings and fuzz together.
Progress has been slow, the poor fit of the model has sapped my positive energy but things are moving now.
I
Those old kits can be real dogs,
I think we must have been way more forgiving of bad fit when we did these as kids!
I am just pleased that Revell have clearly marked this kit as a Level 5 and hope that innocent purchases pay attention to that. There is no way a young and inexperienced builder could put this thing together.
