Mania models 1/72 mitsubishi ki 51 Sonia
That’s coming on well Tony. Like the landing light conversion as well. The Japanese idea of clear bulbs in coloured acetate is far more logical than the British idea of coloured bulbs in clear acetate isn’t it. Far less spare bulb types needed in stores.
The RAF system was a clear bulb which was covered with the appropriate colour before installation inside the clear lens cover. So arguably even more efficient than having a pre-coloured bulb or lens.
Modern aircraft use a similar setup, but I'm not sure if the bulbs are pre-coloured or not.
Landing lights now sanded , polished and masked and the airframe has been primed and given a coat of IJN grey . The yellow leading edges of the wings have been painted and the whole thing has had a quick coat of floor polish to protect the paint while being handled during the next stage . Now the hard bit - the green patches which are going to have to be hand painted . Theyre much too small and intricate to do with the airbrush and from the few pictures of this type of scheme online it looks as if they were brush painted anyway . For this I got a refillable brush pen which should be fine enough . IMG_7838.webpIMG_7840.webpIMG_7841.webp
I've been wondering how you were going to paint the .camo
I'm sure you'll manage those tiny patches Tony, looking forward to the next stage, goodluck (y)
Right , paint pen filled with a thinned green and off we go! The nib takes a few minutes to soak through , its got a spring loaded valve but you work this by pressing it into a hole on the pen top which presses the collar down without pressing the tip of the nib so it doesnt get splayed .
I started on the tailplanes following the pattern on the instructions but then just carried on as random as possible . Its not as easy as it sounds because you naturally tend to form linear patterns as if writing .
Anyways its all done now , I’ll give it a coat of Klear once its had a while to dry then its on with the decals . IMG_7844.webpIMG_7845.webpIMG_7846.webpIMG_7847.webpIMG_7848.webpIMG_7849.webp
Cheers steve , its just so much easier than constantly loading up a paintbrush , plus it doesnt dry out as quick on the tip . Ive had some different ones before with the intention of using them for the smoke ring camo on Italian stuff but the ones I got were too thick , these ones are much better , reasonable too , pack of five in the scale models shop £7.50 .IMG_7851.webp
That has worked really well. Great job Tony.
How easy is it to clean afterwards? Pity it’s GSW world, I don’t use their products. Might look for an alternative though.
Cheers Tim , not sure how easy it is to clean , havent done it yet ! I imagine it would be easy enough apart from the fibre nib/brush . If youre planning on using it for the same or similar colours it should be ok but if you wanted to do something different ( ie red then white) then maybe a new pen or a new nib ( these are available at SMS too )
Didnt know about the hoohaa surrounding GSW , just googled it , very naughty behavior - no wonder people are boycotting their stuff . In my defence I got these months back and not being on the figure painting scene had no idea - if I had I would have thought twice .
Well Tony I've just had a read through as I had missed the start. I have learned a lot. I had never heard of Mania Models or that particular plane. As Pete said you certainly like the unusual.
Great start. Cockpit looks great. Well done with the masking. Wing lights are a worthwhile addition. The paint pen is something else I've not heard of. I will have to look into that. It has definitely helped you produce a superb camo pattern.
The paint result is top notch Tony, wonderful looking camouflage scheme. Never heard of "GSW/Green Stuff World" before; the paint pen concept looks very handy.
Decals on, bit of a bugger though - on putting the first hinomaru on the fuselage it turned out they were a little see through and the camo pattern could be seen underneath. So quickly off with the decal and back on the wet paper . I had to paint white circles under where the decals were going to be placed on the top surfaces ( the underwing wasnt a problem .
All sorted now though and more bits done like the exhausts , machine guns , pitot etc . Its now had the panel lines accented a bit , gun and exhaust staining and a couple of mist coats of matt . Canopy has been demasked and the tubular gunsight fitted ( the kit didnt mention or provide this so a hole had to be drilled in the windscreen and a suitable piece of rod found )
Final few bits tomorrow and it will be done . IMG_7908.webpIMG_7909.webpIMG_7910.webp
All finished now , the last few details to be added were the machine gun and ariel wire , nav lights and the twelve tiny bombs under the wings . I decided to just do a little light chipping . Its been a nice build , a quality kit even though its fifty years old . Ive learnt a few things for the next one ( see through decals for one ) which I intend to do as a reconnaissance machine in the seldom seen dark blue scheme . Thanks to all who have been following , more pics to come on a completed thread . Sayonara Tony sanIMG_7912.webpIMG_7914.webpIMG_7919.webpIMG_7920.webp
