- Joined
- Feb 28, 2026
- Messages
- 707
Thanks Si.Morning John,
Splendid progress with the Ferg and the Dio….brick work looks the dogs danglies![]()
Payment as normal?Diorama at its best, fantastic wall!!
JoeI had to look up Paverpol to see that it is a hardener. That base is looking superb John, and the process is interesting. What does the addition of PVA do to the filler mix?
Thanks John, very informativeJoe
- It stops the filler from peeling or popping off smooth surfaces like wood, MDF, or pink/blue XPS foam.
- Prevents Cracking: PVA adds elasticity to the plaster or filler mix, which reduces shrinkage and cracking as it dries.
- Stronger Surface: The dried mix is much less brittle, meaning it resists chipping if your base gets bumped.
- Looked it up as Ive always done it
Your welcome Joe.Thanks John, very informative
Thanks Joe.Should start some additional sponge work in a couple of daysThe Fergie is looking well worn, great job John
Thanks.Looking well knackered john , are you going to have the bonnet on or off ( or even half open ) ?
Indeed it was Paul.......ah yes..... 'the step too far'. BTDT, have the T-shirt & the sound track.
‘A little too much heat ‘ The title of your autobiography right there JohnThanks.
The bonnet Tony is in the bin! I tried to dent it and applied a little too much heat, resulting in a rather sad-looking piece of plastic.
Tony, come to think of it yes‘A little too much heat ‘ The title of your autobiography right there John![]()
