Joe's Trumpeter 1/72 Mig-29C Fulcrum
Great work Joe. Yes the pre shading has achieved that look of a well used weathered aircraft. I need to get my finger out and move mine on.
Cheers Steve. I'm enjoying the process of this build, once you get your head around Trumpeter's instruction methodology it's pretty straight forward with a great fit.
Excellent Joe, the paint work looks spot on for a well used aircraft 👍
Geoff.
Cheers Geoff
Looking superb joe , exhausts look great and paint is coming on lovely .
Cheers Tony. I will take another look at the exhausts before they go on, not sure if I will add blotches to them or if standard weathering will be enough in this scale.
Just caught up on this one Joe, some mighty fine work, and the pre shading looks great.
Cheers Ian, just need to make a small batch of the green shade.
Looking good; the mottling is coming through well. Are the pylons fixed already? Most kits seem to have teeny-tiny decals for those, so do you put those on after the pylons are already fitted?
Thanks Neil. Yes the pylons are fixed in place. I do this sometimes if they are the same colour as the wing. They do have decals to go on, and I have never had a problem doing it this way.
Nicely done. Pre shade can be very effective and yours has come out a treat. Good airbrush skills (y)
I may try that then. I always leave them off to do the decals and then fit the pylons.
Thanks Jim
If you have multiple weapons hanging off a single pylon (or space is limited) I would suggest avoiding this approach, but as there will only be one missile per pylon, it will be easy to fit them after the decals are on
I made up my batch of the green-grey colour. I didn't have the exact green but I mixed it to be close enough for me using approximately 80% IJA Green and 20% JSDF Grey. I managed to preserve the patchiness of the look I wanted. I aimed for a mixture of softish and hard edges to the camouflage pattern.
Looking excellent Joe , the faded , well used look is perfect for these aircraft , cheers tony
Very nice Joe. Yep the weathering from the pre shade is very effective.
Cheers Steve. The photos have lightened the paint effect a little.
I have a Trumpeter Su27 that I might build soon, if it's anything like this it should be good fun.
Cheers Tony. Can't really go wrong with the pre-war Ukrainian MiG-29s, even then they look to have been very random with their schemes and in various states of repair.
That is a cracking-looking build, Joe. The effect of that pre-shade is really coming through.
Cheers Neil, I used a very thin mix (80% thinner) at very low pressure (10PSI), painting individual sections at a time to build up over the pre-shading.
Minor work on the MiG today. I sprayed the tyres in Tyre Black, then turned my attention to the missiles in white. I painted the gun port panel in gun metal. The camouflage paint is probably a bit dark in this photo, but closer to the colour than in my previous post.
