Andrew's 88mm Flak 37 (The Hunters and the Hunted)
Good to see this back on the go. I like the dio idea - that's a great photo to inspire you.
Cheese can, bread bag, and water bottle should be ok to remain on the basic harness for those in between snacks.
Ok chaps, so I been slowly working away on this at club nights and have finally finished what I think will nominally be the back wall.
The coffee stirrer sticks I'm using are way too thick at this scale....over 30cm in real life, which is a big plank. Therefore, I score a line down each strip (not always evenly or equally)before I glue it on to make it look vaguely like two planks.
There are also a few places where I have done the flanks as uprights, to break it up a bit,
ACW as usual
ATB
PS I will trim all uprights once all the planks are in.
Ok chaps, so have been plodding slowly on with this at club nights, as doing the wooden structure is nice and simple.
I had got this to the point where I thought I almost had it done and then realised I had not cut/left holes for the ammo storage, so had to spend most of the last night cutting them out.
The door you can see, will be the crew refuge...or at least the impression of it. At least that's the hope.
ACW as usual.
ATB
