Neil's Eduard 1/48 Mig-21 PF
I had a nightmare with Mr Color Levelling Thinner. I added a small amount to the primer, which is Mr Model, and it turned into syrup! There was no way to AB it - I threw the lot away, it has done the same in the past - maybe I had a bad batch. The canopy is just on with white tack. I also have a load of filler to smooth off on the underside.
OK, first round with the fine silver - it's going to need a second coat. Also, when I was putting on the stand for the photos, the original plastic 'socket' came unglued and is now inside. Lucky I have more but it will need to be filed down.
Coming along nicely neil , these Eduard 21s are a superb kit , I must do another one sometime . Cheers tony
You could easily spend a year or more (and a lot of ££) just building their different Mig-21 variants, mine has 5 or 6 colour schemes too so no lack of choice.
More nightmares with the airbrush. I'm using Mr Color Super Fine Silver, but it's turning to goop. I tried with two airbrushes, a cheapo no-name Chinese one and an H&S.
I'm thinking of repainting it in Mr Air - I have aluminium and they always work well in the H&S. It just looks blotchy so not much progress at all. Took me ages to clean the brushes afterwards.
I am going to give the aluminium a go - I'll test it first on my test model (old 1/72 spitfire with no canopy).
Neil, it's really weird that you are having problems with using Mr Color lacquers thinned with Mr Leveling Thinner. Are you sure you aren't inadvertently mixing MLT with Mr Hobby?
Oh this is not MLT - it is Mr Color Super Fine Silver and the tin says acrylic not lacquer. I'm using Tamiya thinner - and now I realise that is a big no-no. It should be the same brand paint as thinner is the rule.
I will go check before spraying again. I may need to visit a model shop and get some others.
Shame about the paint but I'm sure you'll get it sorted - the build looks excellent, I may have to go back and read it from the start!
