1/35 T34/76 by TAMIYA 35049 1942 production with metal tracks !
Right, this is where I am up to now.
The base used some dark Tamiya to replicate the soil of Eastern Ukraine. Darker in the riverbed, especially under where the bridge will be, and lastly a mixture of shades on the top of the banks .
Now the T34
2026_5.webpThe hull.
The Fruil tracks are just laid on, need to trim the ends down .
Tomorrow, that chipping fluid, and the winter wash!
John.
I've had reactions when I've mixed other paints with Tamiya, I think its cos they are not water based acrylics like most others.
The dio is looking really good mate..... (y)
Looking very nice John.
Thanks Joe.
Cheers, Peter. I agree; stick to one type!
Love that winter whitewash. Looks really good.
Thanks Jim .
Looks really good, How did you get the chipping effect? cheers
Hi Peter, after the top coat, I sprayed a thin coat of AK Heavy Chipping Fluid. Once dry, I sprayed a coat of TAMIYA XF WHITE. I
didn't leave it for too long, other wise it would have been nigh impossible to remove. Wet the surface with clean water, then start dabbing and, on vertical slopes, use a small, stiff brush to remove downward.
Today I sprayed the whole model with Tamiya X22 clear; I'll let it dry for a further 24 hrs, then apply an oil wash to pick out detail. Hope this helps.
Very convincing paint work John. Did you use chipping fluid or some form of magic?
:ROFLMAO: Yes, see my answer above to Peter.
Thanks Jim .
Ah good, thanx for the explanation. I have some chipping fluid, can't remember which one, I bought it ages ago, but have been too scared to use it! You've inspired me to give it a go next time I do a suitable vehicle.... :) (y)
Great work on the winter camo mate. Proper impressed
Good to see you around Steve.Sadly my time here is over,I appreciated you doing the figure video for me awhile ago.Will look out for your builds on youtube when i can.
All the best from Rich.
