Tim’s 1/35th scale British Archer SP AT gun.
Must say I'm more than impressed with the paint job.
Thanks Jim. Very basic actually. Over all Tamiya XF-61 followed by dry brushing with a lighter shade mixed from Vallejo acrylics, then a wash of dilute black/brown followed by dusting with ground up pastels to give the gritty look.
Thanks Tim. Nothing like a slap on the back of the head to keep the driver on his toes. I like a full lived in interior...shows a little bit of the crews habitual conditions.
Wabble
Cheers Richard. I like a little dirt, but not too much…..and the dust would accumulate in an open topped vehicle like this. Went to a talk given by an ex WW2 tanker once, and he said the bottom of the tank was like a boat bilge. Rainwater, oil and spilt fuel used to wash up and down the bottom of the hull interior as the tank moved.
Okay, this is weird. On the standard Valentine, the gear-stick is on the right, and the two control levers are in the centre, but the Archer seems to have them swapped around
Interesting change
Not sure if I’m honest, I’ve just stuck bits where the kit says 😂. However, the spare ammo is stored this side as this is where the loader worked. The gun optics are on the other side for the gunner to use, so may be that’s why they were moved?
Moved in a bit. Wheels constructed, and bogies etc finished.
Nowhere near as many wheels as a Jerry tank. Just as well really at three bits each.
Nice detail on the suspension units though.
Tracks next, link and length on this build so good definition with simpler construction (I hope). I’ll probably do what I usually do….blue tack the wheels in place and build the tracks around them. That way they can be taken off for painting and weathering, then assembled afterwards.
Evening, Tim. Just read through from the start; looking good. Love the internal weathering.
Cheers John. That’s just drybrush, Vallejo Color wash, and ground up pastel chalks brushed on. Very simple, but effective. Doesn’t take handling that well though as the pastels are not fixed. Great for interiors where handling is minimised, but not so good on the outside of a vehicle.
That's a very interesting suspension set up - it's all looking excellent.
