Airspeed Horsa Glider 6th Airborne mount on D-Day
rtfoe
Shah Alam, Malaysia
Hi,
I have always been fascinated by the exploits of the Airborne during D-Day. No doubt the Longest Day scene on Pegasus bridge captivated me to build not only a bridge captured by the Airborne dio but also the chariot they rode in for the operation. The Horsa glider from Italeri has been with me like ages and in one crazy D-Day inspired year I built a couple of D-Day marked kits and the Horsa was one of them. This is her finished...i'll later take you through her build...
Below for reference only are some pictures that inspired and also gave some ideas to decorate the fuselage...
View attachment 308558 View attachment 308559 View attachment 308560 View attachment 308561 View attachment 308562 View attachment 308563 View attachment 308564 View attachment 308565 View attachment 308566 View attachment 308567 View attachment 308568 View attachment 308569
On the next post I'll start the blog build. Hope you'll join me.
We start with the kit box...
View attachment 308571 You can build either the MkI or II which is the longer version with the huge side loading door.
View attachment 308572 Cockpit detail is not bad. The side pockets on either side of the seats were packed with lead weights. this aircraft is a real tail sitter.
You can already see me stuffing lead under the floor boards of the cockpit. The tail section was easy to assemble with no gaps to fill. Minor sanding was needed.
View attachment 308573 View attachment 308574
The kit comes with a very nice complete interior with fuselage ribbing and seats.
View attachment 308575 View attachment 308576
You will need to cut away the loading door carefully as it will be used
View attachment 308577 View attachment 308578
The loading door is detailed on the inside with supports and ladder that is supplied with the kit.
View attachment 308579 More next...
Good start on this one Richard. Brilliant historic images as well. Love “Angels..” especially...I’ve always wondered if Margaret was hacked off ‘cos her bloke spelt her name wrong....
Tim
Hi Guys, thanks for dropping in with kind comments.
Steve, thanks for the lovely pics of a Dakota interior
Steve O, glad you like them
Jimbo, I don't mind if you want to pull the seats up closr to the table
Tim, don't know but she could be French :smiling6:
Ian, hope the rest is just as good for you
Hi,
Just look at the amount of lead and areas that I managed to stuff them including the top. Base colors applied prior to shading...
View attachment 308761 View attachment 308762
I did some post shading to the interior green by adding a drop of black to the airbrush mix. Picked out detail with a paintbrush...you can just see the lead hidden on both sides of the seats.
View attachment 308763 View attachment 308764
There was aslight step between the canopy and fuselage edge so I added putty to level it off. Carefull sanding to avoid the little nodules on fuselage roof.
View attachment 308765 View attachment 308766
Next the wings...
Paying full attention Richard, I'm with Steve down the front as he's got the biscuits.
Hi John...now there's enough biscuits to go around and I've reserved a seat for you at the front.
Italeri captured the wing right here...thick and broad.
View attachment 308958 View attachment 308959
Preparing all the sections to go together...
View attachment 308966 View attachment 308960
The fit of the wing on the fuselage went well. It just overlapped onto the fuselage without any filler. This was the first time I used CA for seam joints of the fuselage which can be seen after sanding.
View attachment 308961 View attachment 308963
Undercarriage had locating holes on the wing but not the fuselage. Slight dimples on skids were filled and sanded. Any apatures werre plugged ready for airbrushing. I used white glue for masking of the portholes.
View attachment 308964 View attachment 308965
Did someone mention biscuits!?
I love Horsas too, so I'm here for the ride! And Richard's up to his magic again! Yippee!
Anyone bring some wine??
Andy B
Hi Andy, good to have you here...if you're expecting a magic show, it's down the hall way to the left. Sadly Tim will not be joining us so Vino is off the list. Better hurry, Steve and John are already at the biscuits. If you want tea just join the line with the rest of the lads having their sandwiches about to embark later on their Horsa's for the operation Dead Stick.
Hi Steve, the remark on the line of lads waiting to embark would have hinted some figures would be put in but I hadn't done any since. It had crossed my mind for a dio together with the Stirling with lines of paratroops boarding their transports but that would be crazy big. :smiling6:
A bit disappointed that there's no wine or magic and Steve and John have eaten all the biscuits! But I'll stay, because I love what you do! And I'll try to behave!
Andy
Hi Richard
Cracking progress with this. I think the dio in your head may indeed be a bit too big. Shame the biscuits have gone but I shall follow the rest anyway.
Hi Ian, Andy and Jim, thanks for the continued support even without the biscuits and wine. No worries , there's no class monitor minding the class.:smiling6:
