Thinking of having a good old scratch, help needed please
BattleshipBob
Bob
Cardiff
Evening
I am going to have a go at scratching some water, exhaust pipes etc in the StuG's engine bay. Now for some this may seem straight forward but for me a whole new ball game
Some help, if possible
What can i use for the various pipes, plastic rod or something flexible and how the hell do you work out its size??
I can now see theres also plates to make as well, underneath the radiators
Thanks in advance, bob
Bob,
You are a b****y disapointment do you know that, got all dressed up in my bright pink and yellow spandex and bicycle clips, back scratcher in the saddle bag and then realised what you were after.
As Dave said, Slaters or EMA supplies, but i do know they have a minimum order price. For bending use the end or side of a soldering iron fixed in place to leave your hands free.
Mike.
Sorry Mike, trying to imagine the sight of you on your bike :thinking::upside:
Plastic rod is probably your best choice, unless the pipes are no more than maybe a millimetre in diameter and need lots of bends, in that case brass rod or copper wire will also work well. Get all of this from a model shop.
If you can find good cross-sectional drawings, you can probably work out the size from them, if the pipes are visible. Else, you guesstimate :) Use a ruler, dividers, a piece of card or cocktail stick or whatever else you can use to get a reasonable measurement from the model, check photos if you’ve got them, adjust as seems necessary, and make the part. Then find it doesn’t quite fit and try again :)
I have used pre-fluxed solder as a template for pipes, you can bend it easily, then straighten it out to get true lengths, it's a bit soft for permanent fixing, but it's a good pattern. Brass & copper are OK for thin pipes, but get heavy in larger sizes ( not to mention costly! )
EMA Plastruct make extruded sections in styrene, but most of their stuff is ABS plastic, which needs another adhesive...............
Hi Dave,
EMA supply their own cement in liquid and you can get a good supply in fairly cheaply. Dozen bottles in a box, just use as normal and not as smelly as other liquids.
Mike
Personally I hoard off cuts of electrical cable. Coms in all sizes up to about three mil and is soft enough to form things like this. Also look at fly tying lead wire, great for cables etc, and brass pin wire which is great for handrails.
I think plastic rod is the hardest to form like this due to the inherent spring of the material, and it’s propensity to fracture on tight bends.
