Paul's Matchbox GB - Wespe 1/76
PaulTRose
Tattoine
Paul
Tattooine
this is going to be my entry......just going to leave it here cos it will be a week or so before i can actually start
this was a bit of a cockup by Matchbox as the Wespe was never used in North Africa by the DAK.....it entered service as the Axis were thrown out of N Africa and the first of production went to the Eastern front
Remember building this one as a nipper....I did mine in Panzer grey, so was as inaccurate as matchbox LOL. Thinking about it, you could do a desert scene with the Airfix Panther....that wasn’t there either.
Fantastic little kit paul , this was my first go at armour on my return to the hobby about ten years ago . I loved it , the little base and palm tree are great , and the Wespe itself is very nicely done . Cheers tony
done my usual trick of cutting a hole in the hull bottom and bonding in a nut.....that way i can use a bit of threaded rod to make a temp handle
added another cos the combined weight will add a bit of weight, cos since this is so small and light it will help it to sit on the tracks a bit better
hull upper attached to lower and a Standard Calibrated Unit of Comparison to give an idea of size of this tiddler
painted, clear coated, decals added, ready for a wash to bring out details
also finished the little base
