About using aluminium
albertoxepa
hello,
I am interested in using aluminium as a frame for the body of a 1/18th scale ambulance. I have several questions such as:
a). welding. It is difficult, the thickness is 0.8 millimetres and in the tests I have done, I have to raise the temperature of the material and it bends very easily.
Another option is to use two-component "cold-soldering" glue.
b). Painting; I know it is difficult and not just any primer will do. Is it better to sand, decontaminate and use a specific primer?
hello,
a). welding. It is difficult, the thickness is 0.8 millimetres and in the tests I have done, I have to raise the game mod of the material and it bends very easily.
a) Welding aluminum can be difficult due to its low melting point and high thermal conductivity. TIG welding is a good option for precise control over heat input, but if it proves too difficult, a two-component cold-soldering glue can be used.
b) Proper preparation is key for painting aluminum, including sanding the surface and cleaning with a degreaser. Using a specific primer designed for aluminum can also ensure good adhesion and a smooth finish.
Having worked in the aviation business, welding aluminium is a specialist trade due to the difficulties encountered.
We also used to coat the aluminium with a chemical called 'alacrome' (to reduce the corrosive issues the metal is prone to). Then prime and topcoat.
I would suggest a specialist metal bonding compound! There used to be many two part mix that is easy to work and sets like metal. (Been a long time out of it now).
With the thickness of material your using glue is your only option really, soldering ali still needs a great deal of heat.
thank you for your replies
the project is a long-term one; I will keep you posted on progress
