Help!
You seem to have edited out your question.
From what I saw last night I'd wager on a problem with the paint. Have you tried giving it a good stir just in case it's settled heavily and shaking doesn't cut it?
I'd try stirring for a minute, letting it sit for 10 to homogenise, then stir / shake again.
Has it got really cold at any time? Anything below about 4°C can ruin water based paint.
Yes, with my airbrush
It helps if you explain what the problem is , because without any idea the first questions would be
1. is it attached to a compressor?
2, is it set to the correct pressure for the paint ?
3. what paint ?
4. have you thinned the paint ?
5. if so , what make and model of thinners did you use ?
I’ve attached the airbrush to the compressor now and it seems to be working fine now. Thanks
