Any ideas?
Any ideas about what ?Any ideas?
It helps if you explain what the problem is , because without any idea the first questions would beYes, with my airbrush
Going to need more info to get to the bottom of this.Any ideas?
That usually helps.I’ve attached the airbrush to the compressor now and it seems to be working fine now. Thanks
Only if the compressor is switched on, otherwise you won’t get far :thumb2:That usually helps.
