Glass crack
Hello!
I am not sure is this right topic but i found crack in my plane glass. Anyone can tell what is the smartest way to fix it ?
( Sorry for bad english )
There is no 100% fix. If you know the kit maker you could ask for a replacement or source a aftermarket part.
You could glue the join but the crack would always be visible.
One way around is to do it on the ground and add a tarpaulin over it, looks like a glass section for a gun, what plane is off?
I've used G S Hypo cement to fix a canopy and the result was acceptable, but not perfect.
I've seen it suggested that clear varnish can be used. but I couldn't make this work at all.
This is 1:32 Revell Junkers Ju88 A-4's glass part. I try my best to fix it, i will update progress soon.
Right, the rear section of the canopy. I have had a look and cannot find any aftermarket canopies for this model, doesn't mean there are not any, just I haven't been successful.
Hope you get it sorted.
id try using old formula Kleer to 'glue' it together.....then dip the whole thing in it
