for years I have been flushing my airbrush with big standard Halfords Blue Screen Wash without a problem.
Last Monday I popped in for another bottle only to find that other than ready to use, I use concentrate straight from the bottle, there was no standard blue. The only concentrate in store was in either, cherry, berry or citrus scented. A bit annoyed, I got the citrus.
Today, I sprayed primer on some parts of the Triumph 3HW and, as usual, the Stynylrez went on perfectly. I cracked open the new screen was and cleaned my airbrush with a final run through of Mig thinners ready for the Mig paint. I sprayed the Mig colour over the primer and it immediately started to give an effect of being sprayed over a greasy surface.
I will let this dry and see what happens on re spraying but I suspect that a citrus oil is used to scent the screen wash which affected the paint. It wasn't the plastic as the primer worked fine. I shal do a full strip of the airbrush and clean it in Cellulose thinners before re using.
I cannot say for certain that the screen wash is the cause but that was the only difference. Anyone else used it?
