Thanks to those who followed this build. Your supportive comments really helped me keep going when I started to get a bit fed up of this build.
It is not a bad kit, in some respects it is a remarkable kit in that every part of it is certainly recognisable. I would go as far as to say that apart from the engine and gearbox internals, this has every part the real thing has.
It is, however, an old kit and it shows it in the amount of flash and burs there are on the parts, burs being the main problem. What this means is that every round section piece, of which there are a lot on a bike kit, has to be cleaned up including every single spoke. If I had the skills to do it, it would have been quicker to re spoke it with wire. Once built it measures about 9 inches in length.
But to say that it is completely out of the box, no additions or subtractions, I think it is worth the effort to get this classic and very overlooked bike into the display cabinet. I know many would say it should be weathered but I wanted it factory fresh as delivered from Triumph around 1942. Once delivered it would undergo more changes. The Triumph badge would be removed and it's unit badges/numbers put in place.
Needs some care and attention to build but if you are prepared to put the effort in, this is a great kit to build if a little frustrating in places. Enough chat, here she is. Hope you like it.
