Dave W's 1/48 Greek F4E
View attachment 274540 View attachment 274541 View attachment 274542 View attachment 274543 View attachment 274544 View attachment 274545 The missing access panel hole is now filled in.And ive got rid of the step where the radome joins the nose. Next i painted the insides of the engine intakes white. It took 4 thinned coats to cover it . Im away from home and having to use a hairy stick. Normally i would spray these areas.The intakes will need filler like just about every other join on this kit.
Nice work so far Dave, just like your the Phantom I'm doing is a filler magnet
air conditioning pack intakes
I wondered what those intakes were for. On my Fujimi, they were just square blobs of plastic, a bit of filing fixed that.
I'm reading some Phantom pilot memoirs at the moment, and the author talks about two air-conditioning units, one of which could, and often did, do some damage to the pilot's leg when it failed. I wondered if it one of these ?
I was an airframe fitter in the RAF on Phantoms.A long time ago. One side of the nose had cabin air con pack and the other side was equipment air con.Cant remember which was which.
That's them. It was the equipment one he mentions could fail and 'do a bit' of damage.
Coming along nicely Dave. It's good that you are able to identify some of the lumps and bumps from your experience as a former Phantom maintainer. To the rest of us they're just lumps and annoying gaps. :)
I was involved in major overhauls of these things from 1976 to 1988. A long time ago so I don't remember a lot.Im looking forward to the 1/32 Hongkong models kit coming out. I will have to find the money for one of those!.
You don't happen to know anyone called Jim Gaynor or Phil Kent do you?
Gawd I hope that I don't have to spend so much time filling & sanding my one! :eek:
You're doing a grand job of fettling this one Dave.
I which kit are you building Patrick?.Most Phantom kits need a bit of filler.Ive built 2 of the Hasegawa and the Revell kit as well as this one.And they all needed. A fair bit of filling and sanding
I'm doing the Eduard Good Evening Da Nang kit Dave. I recall that Adrian built it a while back & had a bit of trouble with the intake area.
