Weltkrieg 11 deutsche Werkstatt
Thanks Stuart glad you are liking it there is a way to go with it yet.
the easy and quick way out would be to use a tarp,as is there a lot of wire,and pipes,coming of the firewall,?
but looking good,;)
This is continuing to blow me away with all the detail terry...... superb mate.
Work of art there Terry. Just the scale of everything here is amazing.
Stunning work on this Terry it is just amazing.
All the editions just make the build look better and better
Thank you all for your kind words one and all.
Here is just a little update of work done today. I have decided to go along with adding wiring etc rather than the tarp drape I was think of doing. As usual all comments welcome good or bad
Tonight's episode of this build finds the bulkhead wiring finished and work on the crew compartment tilt started. I have found a very big issue with this in that it doesn't fit (not even close) View attachment 276507 View attachment 276508 View attachment 276509 and is going under the knife. To get it anywhere near sitting on the body work I have had to cut the two side over hanging bits off. Tomorrow I will remodel these with some tissue coated in pva then repaint the whole tilt.
Having had a rethink over night about how to tackle the tilt I decided to use the off cuts and some thin bits of styrene.
I then dry fitted the main part and used good old super glue to attach plastic and parts where needed. Then I chucked some filler at it and this is the end result.
View attachment 276544 View attachment 276545 View attachment 276546 View attachment 276547 View attachment 276548 View attachment 276549
It looks rough at the moment but tomorrow I will lick it in to shape (not literally). while I wait for this to dry it will give me time to do other things.
Well I was going to leave the re modelling of the tilt until tomorrow BUT got a bit impatient with the whole waiting thing. It still needs a little bit of a tidy up but I think I am quite happy with how it looks.View attachment 276566
For today's installment I have stuck the front and middle parts of the bodywork down on to the chassis and added the windows. The tilt is only dry fitted at the moment as I am still not happy with how it looks. There is a bit of a gap that is visible along the rear of the crew compartment which I can't get rid of. One thing I have not put on yet are the grab rails which I am now wishing I had done after the PE.View attachment 276694 View attachment 276695 View attachment 276696
I think overall the bulk head looks better for having the extra detailing added and will definitely look the part once in situ inside the barn.
Today the rear body and plough have been put in place the tilt has also been fixed in place. Just in front of the windscreen is a piece of tarp that covers a gap between the bulkhead and bonnet. I have added a piece of tape to look like it would without the bonnet in place. I had a bit of a faff with the rear bodywork as the spare wheel holder got in the way of the rollers for the plough winch. only solution I could see was to remover the spare wheel holder.View attachment 276746 View attachment 276747 View attachment 276748
Superb work Terry, what did you use for the piece of tarp on the bonnet?
I seemed too of missed this build previously, looking at all the pictures it looks amazing :cool:
Thank you both for your kind words they are much appreciated. Scott I used masking tape to create the canvas flap then gave it a good coat of khaki. It still needs weathering as looks a bit to clean at the moment.
Another cracking piece of workmanship gone into this build.
Nice job Terry and like the idea of the tarp
Been a while since I last caught up with this build and it continues to impress. Great stuff Terry! It's blatantly obvious that you're really enjoying this build and it shows.
Great concept, excellent craftsmanship - what's not to like?!!!
Keep up the great work
P
Been following this for a while now. Just never ceases to impress Terry mate. The roof work was unbelievable.
P
Stuart,Paul,Bob thanks for your kind words they really are appreciated.
For a while I was finding it a chore to get anything done in respects to modelling and only really pick at it. I think I had hit a point where I had put so much in to this and not other projects that it started feeling like a mill stone around my neck. I had planned on being a lot further on than this but hey such is life.
Next up for this famo will be the track and weathering. Then I have some serious figure sorting to do to finish the internals of the barn. Stay tuned folks there is a whole lot more to come and as always all comments/suggestions are welcome.
Fantastic!!
I feel for you, but I'm sure you will dicover a middle ground that will streamline the process and meet your need for detail.o_O;):):cool:
