Roberts McDonnell Douglas Phantom 2 F-4C 1/48 Revell ( monogram.
Well a bit more progress to the phantom today if not a lot . After leaving the fuselage overnight to dry and set with glue I started on the wing section or sections should I say as three parts each side make the undercarriage doors and there are also two air brakes.
So on with clean up and black primer 74.602 negro. 2 light coats then sset to dry
On with the filling and sanding of the fuselage.
I taped off either side of the seams so in aid to not to lose too much detail when sanding.
I still lost a lot but I'll be getting the scribe set soon in the post so I can at least know I won't lose all the detail.
The undercarriage bays and doors got 2 light coats of thinned white model air 71.001 I may go over later with a gloss white before sealing the paint.
I'm really enjoying this even if there are a few issues here and there.
Enjoy
View attachment 275965 View attachment 275966 View attachment 275967 View attachment 275969 View attachment 275970 View attachment 275971 View attachment 275981 View attachment 275972 View attachment 275973 View attachment 275974 View attachment 275977 View attachment 275975View attachment 275981
Coming on nicely robert , the cockpit looks fantastic. It seems a bit of a contradiction this kit , some lovely details such as the inside of the undercarriage doors , then some unforgiveable cock ups like the ejector pin marks on the missiles! Keep at it mate its going to look great , cheers tony
Thanks Tony
I'm a bit mystified myself but being an older kit pre 80s I think it has to be said its a little unforgiving at times.
I have the scribing set coming from John at SMS so I'm hoping to try and get some lot detail back.
Because most of kit is raised panel lines I'm going to have to marry the new scribe in with the raised ( daunting at best )
I have not the nerve to do a full rescribe but I'm plodding along with this and I'm hoping to get it primed up by the weekend ( no promises )
Patrick's helping me out with the odd missile here and ther and maybe some decals too etc etc.
It's going a lot smoother than my other Jet attempts
I was even looking at a Sepecat Jaguar GR3 today too!!
Hi guys and gals
I've had a bit more progress on the phantom and the more I'm working on her I'm getting to like this build. Sure there are a few fit issues and I've been doing some rescribing here and there ( mainly detail lost in seams and some tail detail lost.
Wing join was good but I found a nasty gap at tge from join to the nose gear that's been filled and sanded.
Finally got the cockpit glazing masked but still not sure if I want it posed open or closed?
Air intakes at front caused a little feckiling to get right too
Sprayed the rear exhaust area aluminium ( metal coat ) it's had primer and will mask off before I give all over black primer ( once the sanding stops ) is
Pics and comments welcome
View attachment 276642 View attachment 276643 View attachment 276644 View attachment 276645 View attachment 276648 View attachment 276649 View attachment 276651 View attachment 276660 View attachment 276657
Update
Have nearly compleated the main build on the Phantom now but still need to do the odd bit of re scribe here and there through my sanding and smoothing over seams etc. Got some good advice through Papa 695 on my black basing which I'm going to put to full use ( thanks Ian )
Busy last night masking the air intakes and undercarriage bays. I have secured the cockpit glazing in place and after a long session masking I'm pretty happy with it.
Undercarriage and ordinance next to assemble/ paint and more work on the exhaust fans ( burn effect )
Enjoy and comments welcome
Robert
View attachment 276841 View attachment 276842 View attachment 276843 View attachment 276844 View attachment 276845 View attachment 276846 View attachment 276847 View attachment 276848 View attachment 276849
I reckon you're doing a great job Robert, turning this old kit into a gem. Look forward to seeing more progress.
I have been doing some research on the ordinance that the F4C carried and it seems that standard armament was 4 X Aim 7 Sparrows and 4 Aim-9 Sidewinders.
Dubster sent me some external stores as the ones that came with the kit were poor quality and lots of sink holes .
I can use the 4 Sparrows but I have seen there was only 1 sidewinders that Dubster sent me , so I have ordered Hasegawa 1/48 weapons set C which will give me plenty to work with.
Ref shows me that the 4C widely used the Aim-9B
View attachment 276905 View attachment 276906 View attachment 276907
Well after a weeks jury duty I got back to the Phantom. After some rescribing I decided to go for the black basing. Once all masking was complete I used Vallejo 74.602 Negro surface primer all over. I then gave the undersurface's a thin coat/mist of 71.057 Black.
Taking Ian's advice on black basing I then started with a 40/60 paint to thinners light gull grey 71.121 ( USAF underside colour in splotches and swirls ( my swirls not brilliant.
Once this is dry I'll go over again with same colour 20/80 paint to thinners light mist.
I've never done this attempt at painting but it seems rather effective. I also did the fuel tanks same way
View attachment 277033 View attachment 277034 View attachment 277035 View attachment 277036 View attachment 277037 View attachment 277038 View attachment 277040 View attachment 277045 View attachment 277046 View attachment 277044 View attachment 277048 View attachment 277049
Coming on nicely robert , the black base and random swirls looks very interesting , i might have to try that sometime
All looking very nice. The black basing is something I might try (Thanks Ian)
Finished a shift this morning abd came home to postie delivering parcel from China?? Hmm I wonder
Well it was my weapons set C that I had ordered
It's blooming an awful lot of kit that I won't be using on this project but heh there's always spare drawer. Patrick gave me some weapons but I needed a few more
Crisp mouldings and lots of detail and even a weapons layout for each version of Phantom and type of missiles etc carried , lots of weapons and lots of nice decals.
Well I can now get back on with this project.
View attachment 277478 View attachment 277479 View attachment 277480 View attachment 277481 View attachment 277482 View attachment 277483 View attachment 277484 View attachment 277485 View attachment 277486 View attachment 277487 View attachment 277488 View attachment 277489 View attachment 277490 View attachment 277491 View attachment 277492 View attachment 277493 View attachment 277494 View attachment 277495 View attachment 277496
