Last night I masked the nose and sprayed MRP's Medium Sea Grey on the underside. This aircraft was sprayed with RAF colours, rather than Olive Drab/Neutral Grey, so tonight I will be spraying the topside with the MRP, RAF Dark Green.
I first went over the whole of the underside with a very light almost mottled coat. Then I built up the colour with more very thin coats. Here is a pics part way through the process:
Ignore the wheel well covers, they are just there for masking of course....Eventually I ended up concentrating in small areas including but not exclusively the inside of panels. I wanted an interesting varied modulated colour taking advantage of the black base to provide areas of light and dark.
I ended up with this:
The colour modulation is quite subtle in places and is deliberately uneven. When people just spray carefully inside the panels all over the aircraft it just looks quilted and unrealistic, the play of light just is not even across a surface so these carefully sprayed patterns just do not look right. By variating the depth of colour without focussing entirely on the inside of panels I think you get a better impact. Some of the more subtle effects do not show well in the photo.
I finished with an overall light mist coat to bring it all together.
Usually when I spray a 1/32 aircraft using Vallejo Model Air I end up using a full cup of colour, sometimes more. At the end of the session I popped the lid and found:
Lots of paint left. Given the cup narrrows sharply towards the bottom I estimate that about 40% of the paint could be poured back into the bottle.....
I had a feeling with my earlier work with this paint that I was using less colour and this proves it. Applying this very thin paint at a low (10-15psi) pressure in light coats results in using a lot less paint. It is not as expensive as people tend to think. When I summarise the MRP paint review I will do some cost calculations.
Also, it is worth noting - after 10 minutes, as soon as I finished the airbrush clean up, I ran my finger over the painted surface. It was smooth, so unbelievably smooth and with a sheen to it. It also seemed quite hard and resistant to scratches, not that I tried to scratch it. We all know how much longer it takes for Vallejo to get touch dry and how vulnerable it is until it has cured for 24 hours or more (a lot more when you have high humidity). I honestly think that I could have masked up right then to spray the next colour - I didn't as I ran out of time. Oh - it does take a bit longer to lay down your MRP paint in these thin coats but it is well worth taking the time for this result.
I will not need to lay down a gloss coat for decalling.
