Rick's 1/32 Revell Tornado
The two fuselage sections are together complete with the wings and tailerons. The join is a bit ropey along the sides but the tailerons will hide most of it so not much effort required on hiding an unsightly seam. The join at the front on the nib fairings will be okay after filling.
The swing wing mechanism works but the pylons don't work in tandem with them, these will be glued in position later.
View attachment 301103View attachment 301104View attachment 301105
Coming along nicely Rick. My 1/72 Hasegawa had the same step on the rear fuselage fit, must be a Tornado thing, but as you say most of it will be hidden with the tailerons in a neutral position. Are you going to pose the airbrakes open?
No they’ll be closed along with the canopy.
I managed to drop my Tonka on the floor tonight and bent the tips of a wing and taileron - a touch of filler solved that problem. A bit of a pain was the carefully glued, filled and sanded seam of the rear fuselage joins that pinged open, that took a bit longer to fix.
View attachment 302832View attachment 302833
Rick
Nice save on the wing. I enjoyed having a read through of your build. Good luck with the rest
Plodding away.
Forward fuselage to main section has been joined with a little filler and similarly with the fin and exhausts. Fitting the intakes was fairly simple and were nice and snug. You can see a fair bit of filler on the underside of the nose. The instructions tell you to add 55 grams of weight to the nose; that has almost cleaned me out of liquid gravity.
View attachment 306358View attachment 306359View attachment 306360View attachment 306361
P.S. I just want to get this Tonka off my bench to get back on the Airborne Jeep sitting under the bench.
Hi Rick
Sorry to hear about the drop - glad it is fixed. A neat bit of filling on the body. Really starting to look the part now.
The cock pit is now done and the canopy masked and installed using Deluxe Materials’ Glue’n’glaze.
Hi Rick, just had a good read from the start.
Sorry to see it has soft detail and lots of seams, but you're doing a great job and when painted it will look great.:thumb2:
