ICM 1/32 I-16 Type 24
Hi Barry
Good progress. Your attention to detail is very worthwhile.
The more i see the more i want one !! Great progress barry
Btw barry , ICM have also just released a 1/32 polikarpov i-153 ‘chaika’ ,the gull winged biplane that was in production at the same time as the i -16 , looks like another one to get cheers tony
I applied a black primer coat last night. I have found ust a couple of flaws to treat, one requires a swipe of a sanding stick and the other a little filler and sanding.
This little ugly duckling of a plane is coming along nicely. I should be able to get on with some base coats within a couple of days.
Last night I sorted the few flaws I found then I sprayed the underside colour.
As usual I went all over with an initial light coat and then sprayed areas I wanted lighter followed by a mist coat of the base colour mixed with 50% thinner. The latter helps control the contrast between the areas I want darker or lighter. You just apply the mist coats until you get the contrast you want. Very controllable and the best way to get that first stage towards the final weathered appearance. I find that on the underside the black basing is enough to get the effect while on the top, which is subject to more sun exposure, some white is needed in the base colour to get a proper faded look.
This is how the underside looks now and hopefully I will commence with the top colour tonight.
Barry,
the I-16 is looking good - I like the fading on the uppersurfaces. On my 1/48 ICM I-16. I used BareMetal foil for the line around the cowling, I found it easier than masking.
ICM also do the I-153 Chaika, and the Bucker Jungmann in 1/32. The Chaika looks like a similar build ( apart from the fact that it's a biplane! ) - a fair amount of internal detail, that will be invisible when finished!
Hi Barry
The paintwork looks excellent. Your method for creating an initial faded/weathered look is certainly one I will remember.
Barry,
Hi Dave. Yes I have seen those two but the subject matter does not attract me.
But what is exciting is a company not scared to produce less well known subjects in 1/32 as mainstream kits. I think we might look forward to some exciting releases in future.
French and Italian WW2 aircraft maybe and there are some interesting Russian subjects so far only kitted by short run companies.
I have applied an AK panel line pin wash and then I applied the first matt coat.
Now I do a number of treatments before a final matt coat
The smoke pigments to brush on strategically for exhaust/gun residues, some earth pigment where mud will get splashed, an exhaust wash and a brown wash for streaking effects underside. As much of the airframe is wood I will want to depict the paint on high travel areas as worn and for that I am going to try the oil dot method using a whole range of different brown/earth shades. I have no idea how that will turn out so it is something of an experiment....
The metal powder pigment has sneaked in the picture but that wont be used until after the final matt coat because I will want the chipped/worn metal to have a metallic gleam, likewise oil and kerosene leaks will be applied after the final matt, again so they have that oily sheen. It all adds depth and texture..
What a great looking model, it really does go together very cleanly topped off by a top notch paint job.
A little more progress.
I have applied some pigments, streaking and the oil dot treatment which has left a brownish patina in high travel areas. The latter is a very subtle effect that does not come across well in the photos but it does help give the impression of painted wood, wearing a bit.
I then applied the final matt coat.
there is still a little weathering work to do and a bit of detail to 'refresh' before I move to final fittings.
Hi Barry
Superb finishing. The layered up effects really raise this to another level.
Thanks everyone. I am/have posted a completed thread in the right place
