"Pete's Toon Sturmtiger Conversion "
Hi this a Tiger 1 conversion to a Sturmtiger, Toon don't make one yet so I thought I would give it a go.
Donor kit.
Parts I'm going to using.
Parts in black to be removed.
Drilled out track links and removed the end links. (before & after)
Made R/H & L/H wheels and rear panel adding some missing detail.
Made up rear deck.
Started work on the gun housing block.
Thank you for looking in, all comments welcome good or bad.
Pete.
Hi Pete
You're really taken with these Toon Tanks aren't you. They are certainly great fun. This is a good idea and I have no doubt it will be a brilliant addition to your collection.
Brilliant idea Pete, and by the looks of things this is going to be great.:thumb2:
I shall follow, hopefully I will learn something.
John.
Loving this, great idea.....going to be a good ‘un....
Hi got a bit more done, just the gun to make???
Pete.
Pete your mad.
Just seen this one, and what a great idea also what great work so far. I'm sure Meng would love your plans for it and no doubt any others you'll be doing.
Very nice work Pete
SturmTigers are very popular at the moment
Love the full sized one too
Regards
Steve H
Pete your mad.
Cheers Ian and yes I've got three or four more lined up none are on available yet.
Pete.
Totally awesome dude! Are you going for disc, dot or streak camo??
Hi Steve thank you, once I've built the gun I'm going for disc camo pattern like it's big brother :fearful::upside::fearful:
Pete.
Hi gun and gun shield on plus M/G gave the shield a coating of Geso Liguitex to give a cast look. (dries matt in 24h) Added weld seam.
Made up raised wheel hubs.
Made wheel spacers to give a wider look to the vehicle.
Pete.
