UH-34 in the Padi
rtfoe
Well-known member
Shah Alam, Malaysia
Hi Ya'll,
I thought I'd keep Fernando company with his Wessex build. This though is completely different...firstly it's in a different scale and is set in a diorama. This one...
It all started when I acquired an Italeri kit of the UH-34 and on opening the box I found the details very crisp, clean and calling out to be built. At this time i was into doing something Vietnam after watching a few documentaries on the conflict. Although the Huey was the iconic symbol everyone saw of the heliborne warfare in Vietnam, I was more intrigued by the earlier variants used in the conflict such as the flying Banana and the UH-34. In the early stages of the war the ARVN or Army of the Republic of Vietnam were flown into combat with their American advisors or officers with Marine UH-34's and Huey Gunships as cover. One such mission was on a hamlet call An Bac surrounded by rice padis....hhmmm I thought I could do that so off I went...
I started by painting some of the interior parts whist still on the sprue as most would be hidden from view I did basic shades. I would have wanted the canvas seats to be red but these were to be Khaki or Drab.
View attachment 315029 View attachment 315030 View attachment 315031
I hope there are those who are interested in Vietnam era subjects and helicopters and rice padi fields. Just to let you know that it is a completed build so will post more later when I can figure out the sequence of images and re-write the blog that was erased from the previous forum that shall not be named ...
That's a great diorama Richard, I will follow along with how you built it. I really like the ripples and blowing grass.
Quick response there...
Greg...I was sure you'd spot the Marines marking...will check on the movies you remembered that may have the UH-34.
Ian, thanks Bro...this dio really had some planning to do with all that hovering. The ripples were the fun part not so the blown padi.
The interior was easily put together...no fit issues. Later I added padding when I suddenly had the urge to extra detail it. At the time I didn't know I had been affected by the Simon syndrome for scratch building...
View attachment 315058 View attachment 315059
The kit comes with closed cockpit windows and that just didn't do in the tropics. You had to have them open for cool ventilation so cutting them out and replacing with pla strips was the way to go.
View attachment 315060 View attachment 315061
Followed the rule...measure twice and cut ...measure twice and cut...:smiling6:
View attachment 315062 View attachment 315063
The existing cut out window frames were used as templates and guides. Supports held the fram in place while the glue set. Alignment was very critical and so often the clear canopy was placed over for fit check.
View attachment 315064 View attachment 315065View attachment 315066 View attachment 315067
I sliced off the outer main frame and left the inner frame to hold the clear window part. There was a lot of sanding to thin it before gluing the parts together. Now with this I could slide the window back along the new frame.
The kit is perfectly good just putting it together but I had to muck about...:rolling: hope you're still with me on this.
Hi Ya'll,
These next set of pictures will make you think that I was out of my mind and truly so. The kit molded mesh is fantastic but I had steel mesh lying around that was crying to be used more so that a silhuette of an engine seen through the mesh was just forming in my beserked brain.
View attachment 315120 View attachment 315121
Before cutting away the molded mesh I traced the frame which actually could have been done even after cutting. The mesh had to be cut closely to the edge so that it could be glued flush. Besides I wasn't going to waste overcutting the mesh as I had only a small piece.
View attachment 315122 View attachment 315125
I thinned out the back using a grinding chuck. I got it thin as humanly possible...the last bit edges were shaved with a blade. Same thing was done for the tail vents.
View attachment 315126 View attachment 315127
The mesh was then attached with cyano/super glue...slowly teasing it into the edges carefully making sure none creap onto the exposed mesh. I used the end of a paint brush to nudge the mesh into place.
View attachment 315128 View attachment 315129 View attachment 315130
Now the engine is another story...
Hi Richard.
I remember seeing this as a completed dio but I don't remember the build itself so I'll enjoy following along. Excellent start. You are definitely morphing into a Simon T. The mesh is excellent and very neatly done. The open windows are a real improvement.
Thank you gentlemen,
Peter, luck was with me that the scale of it was right.
Dave, some kits are worth going all the way.
Greg, would you believe it i found it on the roadside. Probably fallen from a service truck for an aircon or condenser unit of some kind.
Jim, Simon T I may not become...he is from another world. :smiling2: The kit just cried out to be cut up. Glad you can see it from the beginning.
Ian, it was a crazy moment of sudden indulgence but glad it turned out alright.
AHAHAHAHAH OMG.... I thought I WAS THE ONLY ONE to grab stuff from the ground to re-use it in dioramas...... THANK YOU RICHARD.... feel much better now :smiling5::smiling5::smiling5::smiling5::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy:
Greg, :tears-of-joy::tears-of-joy::tears-of-joy: We diorama guys just think alike. I have a collection of dirt and dried foliage ready for my dioramas.
Hi Ya'll,
Now obviously I had opened pandoras box. With the mesh an engine will definitely be needed. The kit doesn't supply it so some gizmology, firewalls and compartments were fashioned from spares and plastic sheets. The drive shaft ran right under the cockpit floor through the crew compartment up the top connecting to gears rotor shaft. So sifting through references on interiors assisted with this.
View attachment 315183 View attachment 315184
Some holes were plugged, quilted padding was made with putty. The engine parts came from some tank cooling fans...
View attachment 315185 View attachment 315186View attachment 315187 View attachment 315188
The exhausts were treated by thinning and adding three sided bracings and painted rust. The dashboard recieved wash and drybrushing to bring out the dials.
View attachment 315189 View attachment 315190
The quilt padding and engine were painted and weathered. Pre-coloured wire enhanced the plumbing...
View attachment 315191 View attachment 315192View attachment 315193 View attachment 315194
Everything was attached and checked that it was enough to be seen through the mesh. I realised often a well detailed dashboard is sometimes overlooked in a dio so I didn't bother to do more than was needed.
View attachment 315195 View attachment 315196
So far so good...
Ooooh, very nice indeed Richard.
Even if you say you are not like Mr T from the dark side I agree with Jim. Like the others that mesh is superb, along with the engine detail.
It was before my time in the other house , so I've donned my wellies and paka Mac and am sitting in the third paddy row from the front .
John Trench foot
Hi John, you have just made me realise that all this time I had spelt "paddy" as "padi" which is in Malay...like Paddy Fields is Sawah Padi. It's in the title so I must be confusing many wondering why a UH-34 is in a "Padi" :tongue-out2:
Thanks for that.
While you're in your wellies in the paddy, bring along a small net...you might spot a fighting fish or two or even guoramis.
Hi Ya'll,
The top transmission shaft also had ventilation apertures with coarser mesh. I cut out the molded mesh and used mesh from one of my wife's discarded bags. Plastic rod was added to simulate cyclic prop shaft to the tail.
View attachment 315220 View attachment 315221
For the top transmission gear gizmology I used return rollers wheels from an M60A1...sprayed them silver and weathered with grime wash. Through the mesh they looked the part.
View attachment 315222 View attachment 315223View attachment 315224
When closing the fuselage halves together I puttied any gaps and dry fitted the canopy...some sanding was required for a snug fit.
View attachment 315225 View attachment 315226
Exhausts look ok...last minute sanding of frame before painting the inner edges interior grey.
View attachment 315227 View attachment 315228
I was quite satisfied that the engine and its plumbing could be seen through the mesh.
View attachment 315229 View attachment 315230
All gaps filled and sanded down.
View attachment 315232 More to come later...
Hi Richard
Putting in the mesh was fiddly enough but then you had to fabricate an engine etc. You have done that very well and it will certainly look good although as so often happens not a lot will be seen. You have got the canopy to fit well.
