Only two more needed....any taker???
Tools permitted will be the minimum of what is needed ie : knife,spure cutter and sanding stick or what ever you have to hand but it has to basic.Peter,
Apart from the included brush what would be the permitted tool list or could I use whatever tools I wanted as long as no extra materials are used?
Hi Simon!! You will play??Thanks Peter
Dave - good find on that TKS, I like them. Just been having a look though and they don't include glue outside Poland
Is that one a pure starter kit or just a normal kit with paints included as it must say on the box starter set or equivalent.A bit more searching, and a surprising model is sold with paints, brushes & glueView attachment 321182
Hataka paints at that!
My fault as I forgot about the cars I have done plenty so I should have known.Don't think I shall bother with this one thanks
I would just note that limiting it to 1/72 or smaller means you won't be seeing any cars as they are 1/32
Ok it's in.View attachment 321195
Translation of the Polish ---
"starter kit ( quick assembly ) contains glue, paint and brush"
Hannants & others say glue included.
Any starter kit is suitable so it's a case of pick what you like.Hi Peter
In your initial post you say the build will last for 3 months. Do you know yet which 3 months?
In our Aldi they have starter kits for £4.99 which would suit this I think.
My problem is that starter sets over here are about as common as hens teeth. I think I have seen them once in 30 od years!!!
