Airfix 1\24 Hawker Typhoon (second bite)
peterairfix
Peter,
That should keep you out of mischief for a while. I will pull up a chair and follow along.
Hi Peter
That is a lot of plastic. As Scottie says it will keep you busy for quite a while.
Looking good Peter. I’ve been building one of these on and off for the past year or so. It was all going well until I came to fit the engine cowlings. Gaps galore. Hopefully I will finish it soon.Look forward to seeing yours come together.
Wow! A lot to put together. Hope it all aligns accurate to not cause problems. Looking really good and pilot is together. Going to have to follow this :thumb2:
Everything lines up really well if you take your time with it. The only bad fitting parts are the upper engine cowlings.Not a problem if you want the engine on display
Thanks Dave, be good to follow Peters progress and indeed look at the engine cowling :thinking:. Just wonder why everything lines up but an issue with the cowling.
I thought it was something I had done wrong. But even Barry W had problems with his
Hi Peter
Looks great so far. Love the detail on these larger scale planes. Glad everything is lined up OK as some of the early photos looked rather awkward to get all nice and square.
