Billings boat's HMS Bounty.
The planking is nicely done Peter.:thumb2:
Reminds me of a Spanish jolly boat I built a while ago, very time-consuming but when finished very rewarding.:smiling:
Moving on I have the starboard planking complete and the port side is halfway there.20190219_150108.jpg20190219_150121.jpg
Whhhaaaaattttt???, laser cut, keel already built, whatever happened to boat building, where is the smell of glue boiling on the stove, the smell of wood shavings....
This is looking very good Peter, are you pinning the plank or are those pins just holding, and did you have to steam the planks first?? I could be seriously tempted into a build like this, well impressed.
Cheers, Mike
Cheers, Mike
Pins are just for holding and the planks only need a quick soak in water as they are very forgiving.
Cheers, Mike
what mike said im impressed
chris
All the planking is finished so it's away with the pins and out with the sandpaper and filler.20190221_073529.jpg20190221_073510.jpg
Hi Peter
That planking looks very neat. I'm impressed. It will be stunning when complete.
Lovely bit of plankin Peter an now you got the job I hate an that's filling all the cracks an then sanding down the hull are you gonna use sandin sealer on the wood ? as that's what I will have to use when I get that far on my 8ft hms tiger hull if I can build her ok that is. But anyway a crackin job well done an very neat on the bow I tip my hat to you sir
chris
Nice planking and very quick! Is there a second planking?
what glue are you using Peter?
Jon.
There is only one layer of planking if there was any more I would be heading for the hills.
The glue I used is Evo stick interior wood glue.
Planking now done and a whole day of sanding and sanding and more sanding and painting and varnishing has produced this.20190222_180102.jpg20190222_180039.jpg
Peter, are you aware of the Ships of Scale Forum. It may be of some interest to you.
