Pete's Lancaster Bomber
Great build so far. Just a little note (if you didn't know), the exhaust staining only goes over the wings on the two inner engines and the inner side of the outer engine. The outer side of the outer engines went totally under the wing.
Hi thank you for info on the exhausts good to know :thumb2:.
Pete.
Just caught up Pete and the bouncing bomb with mounts look great.:thumb2:
Love the added details and even some figures too, the finished look will be grand.:smiling:
Hi finished messing around with the cockpit now.
Added joy stick and navigators light and instrument panel.
Thank you for loking in , I know I'Ve got a lot off cleaning up to do :tired:
Pete.
Hi there got some paint on at long last.
Thank you for looking in.
Pete.
Hi I never got around to up loading this lot before I went into hospital.
As you can see I have got out the hairy sticks and tried to do a camourflage pattern, applied decals which are the stickers that came with the kit :sad:.
Hope you like it I'm all most done with this one.
Pete.
Fantastic work Pete, really liking all the modifications you’ve done to this one.
Wow fantastic Build Pete! I was only looking at this kit on Sunday , Just shows what you can do with a bit of scratch building.
c
Hi Ian thank you for your kind comment, it took a lot longer than I thought but the end is in sight.
Pete..
c
Cheers Ben very much appreciated, thank you for stopping by, I think there great little kits the only thing wrong is the decals there stickers not good at all to work with.
Another great build Pete, just remember when you thought no one would be interested in these beauties. I've noticed so many manufacturers starting to make them as well .
John.
John.
Hi John and thank you very much, that's true but there are some people that like to call them toys or paper wights. I just like building them and will continue to do so.
Pete.
Hi had a gentle start at the bench with the Spitfire base so I made the base for the Lancaster as well.
I use white card cut into a circle, added static grass, grass tuffs and flowers.
Pete.
