Great build so far. Just a little note (if you didn't know), the exhaust staining only goes over the wings on the two inner engines and the inner side of the outer engine. The outer side of the outer engines went totally under the wing.
Hi thank you for info on the exhausts good to know :thumb2:.Great build so far. Just a little note (if you didn't know), the exhaust staining only goes over the wings on the two inner engines and the inner side of the outer engine. The outer side of the outer engines went totally under the wing.
Hi Ian thank you for your kind comment, it took a lot longer than I thought but the end is in sight.Fantastic work Pete, really liking all the modifications you’ve done to this one.
Cheers Ben very much appreciated, thank you for stopping by, I think there great little kits the only thing wrong is the decals there stickers not good at all to work with.Wow fantastic Build Pete! I was only looking at this kit on Sunday , Just shows what you can do with a bit of scratch building.
c
Hi John and thank you very much, that's true but there are some people that like to call them toys or paper wights. I just like building them and will continue to do so.Another great build Pete, just remember when you thought no one would be interested in these beauties. I've noticed so many manufacturers starting to make them as well .
John.
