Hi all, having recently bought an A-10 kit I know I'll need to add some weight to the front to stop it sitting on its tail. The kit suggests around 50g in a space behind the cockpit. There seems very little room right up in the nose where it would be more effective, but I'll know more as I start to build it.
I grabbed some used wheel balance weights from work as I thought they'd be ideal, but I don't think they'll be dense enough now that I've seen the limited space available, and they aren't pliable at all to try and squish into place.
I used to buy small quantities of lead to add mass to scratch built speaker cabinets from a company called Lead Shot Ballast. They had various sizes of shot and sheet so would have been ideal, but it looks like they are no longer around. I'm guessing one alternative to that would be lead fishing weights, but they seem to work out expensive for the weight you get.
For now I've ordered a roll of lead strip normally used for holding plants down in aquaria, but wondered if you guys had any other suggestions that you used regularly.
Thanks,
Andy
Thanks,
Andy
