Tamiya's Masterpiece - Their 1/32 scale Mosquito
Still on your favourite 1/32 Barry.
As your usual work nice controlled accurate stuff.
Now is yours a Canadian or British built ?
Hi Laurie, Thanks British built, Polish Squadron.
Some more pics:
I have been detail painting more of the interior. They have had a gloss coat and I will be weathering tonight/tomorrow then applying a semi-matt varnish.
The fuel tanks were sprayed MRP Red Oxide Primer after spraying RAF Grey-Green and masking off the straps.
The underside of the wheel wells and bomb bay.
The cockpit rear.
I have been working on the wheels. Brilliant engineering that only Tamiya and one other manufacturer could pull off this well.
The individual tyre sections being fitted around the rim.
Perfect fit, flattened tyres, with no join showing at all.... Another six tread pieces to fit.
I got thinking how other model manufacturers would have managed with this kind of engineering:
Revell - fit would be OK but the parts full of flash and sink holes, lots of clean up needed and plenty of filler, 'soft' detail.
Airfix - they can certainly engineer parts like this but their manufacturing would let them down with their poor quality plastic needing clean up and, no doubt some filler work needed.
Dragon - perfectly clean molding, perfect fit but the instructions would leave you wondering just what to do with it!
Trumpeter - clean molding that fits reasonably well but something would be just wrong....
Hasegawa - clean molds nice fit but missing detail (out comes the lead wire on the legs....)
Wingnut Wings - perfection to mirror Tamiya's....
Hi Barry
You would think that by now the instructions would be sorted.
Your work is so neat and well thought out. Inspiring stuff. That tyre is amazing - never seen the like before.
Hi Barry
Wow some work on those tyres Barry. Very nice to see such detail.
Gives a a great feeling when building.
Who is the other one Barry ?
Wingnut Wings Laurie
Barry, great build , taking lot of interest as this is my next build , your pics are of great help , will use
This as a guide for when I start build , great job.
Wheels dry brushed with a Dark Earth pigment.
And fitted into the legs. Note the jigs Tamiya provide to help assemble them.
Here is an overview of the components so far. I will be joining some of these soon
Barry those tyres look superb , could you explain how you do this , have not done dry brushing before,
Intrigued how and materials used . Thank you.
I primed with black primer then sprayed MRP Rubber Tyre. When dry I used a stiff brush to brush on AK Interactive Dark Earth pigment, brushed dry. I finally use a softer brush all over to get the dusty rubber tyre look I wanted. Simplicity in itself.
Brill Barry , do you use a binder with soft brush
Also Barry who make the rubber paint , sorry but I want to learn
They are MRP - their laquer solvent range is probably the best paint for models that you can get for the airbrush.
Here is a review of them I did a while back:
https://www.scale-models.co.uk/threads/mrp-paint-detailed-review.28812/
There are plenty of other reviews out there:
https://doogsmodels.com/2015/11/27/test-drive-mr-paint/
here is their website:
http://www.mrpaint.sk/
You will need to Google to find where to get them.
https:tongue-out3:/www.scale-models.co.uk/threads/mrp-paint-detailed-review.28812/
https:tongue-out3:/doogsmodels.com/2015/11/27/test-drive-mr-paint/
http:tongue-out3:/www.mrpaint.sk/
thanks Barry , still not sure about last part , do you use any liquids with the pigment
No Peter. I just brush the pigment in no liquid, best on a matt surface. That way you get that nice dusty effect.
