Cheers barry
You would think that by now the instructions would be sorted.but the instructions would leave you wondering just what to do with it!
Hi Barry
Your work is so neat and well thought out. Inspiring stuff. That tyre is amazing - never seen the like before.
Wingnut Wings LaurieWow some work on those tyres Barry. Very nice to see such detail.
Gives a a great feeling when building.
Tamiya and one other manufacturer could pull off this well.
Who is the other one Barry ?
I primed with black primer then sprayed MRP Rubber Tyre. When dry I used a stiff brush to brush on AK Interactive Dark Earth pigment, brushed dry. I finally use a softer brush all over to get the dusty rubber tyre look I wanted. Simplicity in itself.Barry those tyres look superb , could you explain how you do this , have not done dry brushing before,
Intrigued how and materials used . Thank you.
Brill Barry , do you use a binder with soft brushI primed with black primer then sprayed MRP Rubber Tyre. When dry I used a stiff brush to brush on AK Interactive Dark Earth pigment, brushed dry. I finally use a softer brush all over to get the dusty rubber tyre look I wanted. Simplicity in itself.
Also Barry who make the rubber paint , sorry but I want to learnBrill Barry , do you use a binder with soft brush
thanks Barry , still not sure about last part , do you use any liquids with the pigmentThey are MRP - their laquer solvent range is probably the best paint for models that you can get for the airbrush.
Here is a review of them I did a while back:
https:tongue-out3:/www.scale-models.co.uk/threads/mrp-paint-detailed-review.28812/
There are plenty of other reviews out there:
https:tongue-out3:/doogsmodels.com/2015/11/27/test-drive-mr-paint/
here is their website:
http:tongue-out3:/www.mrpaint.sk/
You will need to Google to find where to get them.
