Tamiya's Masterpiece - Their 1/32 scale Mosquito
Just having a catch up Barry. All looking great. My only worry is, whatever you build next, you might just be a little - let down by the kit ?
Not if it's the new 1/24 Airfix Hellcat!
That Hellcat looks a nice kit and I may well be tempted but my concern is that like the Typhoon in that scale while the engineering will be superb the manufacturing will let it down. That awful soft poor quality plastic Airfix uses is a real problem. With the Tiffy you spend as much time cleaning the mould lines, sink holes and filling gaps where the plastic clearly shrunk, as you do assembling the parts.
Hi Barry
That last set of photos show what a great kit this is and what a superb job you are doing with it. The detail is stunning.
An amazing level of detail in the kit, brought together and finished superbly.
I have started to pull together the front cannon assembly
Note the p.e. jigs to ensure that the barrels have the right spacing. These will be removed before the next stage of the assembly, more thoughtful Tamiya engineering.
I will not be leaving this area open to view but I will have the bomb bay open.
I am having the bomb bay section open and gun bay closed or on other words ‘half open’ as per the Tamiya description.
The bomb bay doors come as a single piece so some cutting is required.
I used tape to provide a guide to the cross cut.
I then used my finest razor saw to cut, working slowly and letting the saw do the work.
Here it is after cutting needing only a swipe of a sanding sponge
I then did the same to separate the two bomb bay doors.
Her is a view of the next lot of sub assemblies ready to paint except for the two bombs as I have some sanding to do having treated the seams with Mr DIssolved Putty
Fantastic build Barry whats happenin on her now ?
chris
Progress seems rather slow this week
Here are some bomb bay parts painted, weathered and ready to install
Between waiting for parts to dry I have been pulling together various sub assemblies.
Really coming along, Barry you've most probably already said but what camo are you doing?
I have put together the inner canopy frame. There is a little tidying up to do, brought out by the expanded photo.
I have painted the canopy itself as well. A test shows that it fits perfectly over the frame. I will be removing the masking, gluing or it place and then remasking for when I paint the fuselage.
Sound odd removing the mask and remasking but I have decided that the clean up will be easier off the model.
Hi Barry
Everything is looking sublime.
That sounds like a very wise decision.
