Your Welcome Chris be dropping in to check the progress now and then
Chris,
the joys of short run models! I leave the glue well alone until I've dry fitted and adjusted things for 'best' fit. It can help to add plastic card strips to aid location in fuselages. I go back to the old method ( from making vacforms ) by having a sheet of wet & dry on a thick piece of flat board, and sanding component faces square ( use wet, less dust! ) - I even do this on mainstream models occasionally, if needed, removing location tabs/pins in the process.
Good tip! Won’t be the last time I need this, so thanks!Chris,
with short run kits, and butt joined wings, I drill holes in the wing roots & fuselage <1mm dia, and use copper wire as the strength member - copper, so you can adjust the dihedral, etc before committing to cement!
Two of the same rather than a left & right pair?Can anyone tell me what is wrong with these elevators...
