Lovely crisp details, as I've come to expect from your work.
This review on Cybermodeler.com provides the answer:do the weapons when fitted to the hard points angle in an out when the wings move forward or back like on the real plane ?
The underwing pylons are designed to be attached to the wings so that they can move with the wings as per the real aircraft, this was another weak spot on the kit as the mechanism for allowing this is a little crude, consisting of a four little plugs that are attached to the various pylons through holes in the lower wing parts, but it makes the pylons very wobbly
jakko thanks for lookin up the answer to my question cheersThis review on Cybermodeler.com provides the answer:
I’d glue that with two-part epoxy for strength, after thoroughly cleaning the metal parts, especially the areas where they will be glued.The SAC white metal legs fit well into the plastic but I am not sure how well they will hold. May be OK
