Hi Graeme,Hi Paul, I'm doing the slightly updated & re-boxed as Tamiya version on the Recon GB, so I'll tag along to see how you get along.
Glad you found them mate you may need them later.Sorry I'm late. Looking good so far. My Wayfarers (much darker than Raybans) were in the Corvette, so had to find spaces in the garage for the crap in the way of opening the door. PaulE
I must admit they do look fiddly, that's why on looking at the kit I thought it would be easier to remove the deck completly to make it easier.This should be good - seven frets of etch :surprised:
I did their 1/48 version and added etch - the engine deck grilles were all separate slats and frames and it drove me mad trying to get it all to line up. At least this will be a bit larger being 35th
Hi Scottie,
looks like your off to a good start on this rather old and difficult build.
Good call on replacing the deck plate.....should be a lot easier than messing about with the kit offering.
i just had a google on that Griffon PE set :surprised:....blimey mate that’s a full on set but it certainly looks to cover everything but the kitchen sink!
I have every confidence in you that this will look wicked mate![]()
John, Good to see you mate.Paul .
I'll take my normal seat in the corner, I've left all my combustibles at the checking in stand, and have safely stored away my ticket .
Andrew, thanks mate hope I haven't bitten off more than I can chew.Good luck on the new engine deck!!!!
ATB
Thanks Ralph hope it is worth watching.Looking forward to this Paul :smiling3:.
No mate loads of room good to see you.am I late for a 2nd row seat?
Ian, good to see you mate welcome aboard.Hi Paul I'm another one joining in at the back.
Chris plenty of room mate. Good to see you.An me :smiling2:
HI Jim what you said is very very true poor Scottie as ive found out but most of my lost bits to the carpet monster is usaually nicked off him by mr hover pushed by SWMBO :smiling:Hi Scottie
Those etch brackets looks far better. Your replacement for the one stolen by the carpet monster is excellent. It is often difficult to place PE parts correctly. The carpet monster will probably return the pinged off piece now he has had a good chuckle watching you crawl about on the floor and then waste an hour scratching a replacement :rolling:
