SimonT - Trumpeter 1/35 Egyptian IS-IIIm
SimonT
Morning all,
this is another one that I have been chipping away at in the background for some time now
I have had a concerted effort to finish cleaning up the track links and they are now ready for assembly
the kit is one of their older ones so not up to their current standards. No etch and rubber band tracks
In no particular order here are a few pictures I have taken along the way
fuel tanks - new filler caps and weld seam from filler
rear smoke drums get etch end plates
barrel is aluminium tubing with a modified kit muzzle break on the end
fuel drum mounting holes filled with bits of sheet plastic
various bits of etch, new bolt heads, lifting eyes drilled open
welds added to engine deck louvres, grab handles replaced with brass wire and heavy duty welding added with filler
side skirts scratched from pewter with punched plastic bolt heads
red paste added for texture
casting numbers added from Slaters plastic lettering
tie down strap is from the Eduard etch set
Masterclub resin links all drilled and sanded
rear track guard from pewter
front end from pewter with etch hinge
I was wondering when this bad boy was going to make an appearance. Lovin the work so far but really interested in seeing the wet stuff on this cracking build
Hi Simon
Well worth taking this down from the shelf. So much work done already. "Red paste"?? - go on what is that?
Steve - I’m rather looking forward to getting some paint and dust on this one
Jim - Vallejo textured acrylic paste, great for rough surfaces
Hi Simon,
That is looking like a cracking build - do not put it away again..
Cheers, Mike.
And there was me thinking you'd been carrying out self mutilation again :tongue-out3:
Interesting build Simon, looking good so far :thumb2:
Mike - ta. I shall continue chipping away at it
Jim - not recently (famous last words). It is this stuff RED OXIDE PASTE
Steven - thanks
P.C.O. Mr. T, you now have my undivided attention. Nice work so far, glad you are back at it.
Rick H.
Can't keep up with the amount of builds you have going Simon.
Love the rear resemblance to the T34 slope. Pewter out in force :thumb2:
