Amati 1\250 RMS Titanic full kit
Hi Peter
Thanks for that. I could understand that a ship which in reality had planks would look fine with wooden planks but I was a bit puzzled with using planking for something like this. I can appreciate the sanding will be very dusty :rolling:
And after a day of sanding and more sanding with a little bit more sanding and some filling and then more sanding here's the result and then on to the next stage which will be the second layer of planking that holds the portholes.20191112_151144.jpg20191112_151230.jpg20191112_151254.jpg20191112_151306.jpg20191112_152040.jpg
Hi Peter
As Andrew said that is the result of a lot of time and effort :thumb2:
On to the next stage witch is adding the second layer of strips that have the portholes and completes the hull before painting I have only shown the first two pieces as the rest is much the same20191114_145404.jpg
Time to update I have finished off the second layer of planking and all the portholes have been fitted and the black and paint have been applied.20191121_151341.jpg20191202_083427.jpg20191202_083427.jpg20191205_125522.jpg20191208_105831.jpg20191208_110255.jpg
Peter
Amazing work. Hats off to you I wouldn't know where to start!!
Very well done indeed.
Nice progress Peter, looks like a lot of work :thumb2:
Big update I have finished the hull off and added all the etched doors the boat deck has been planked with other parts and I have added the etched A and B Deck etched sides20191223_131350.jpg20191225_140850.jpg20191225_130602.jpg20191225_140915.jpg
Hi Peter
One heck of a task you've taken on. Really starting to look like the Titanic now :thumb2:
Started on the funnels as per instruction manual I have done no's 3 and 4 and also the before during and the completed funnels.20191226_125608.jpg20191229_103644.jpg20191229_103658.jpg
