Neo,
Looking good.
Looking good.
Thank you,Scottie! I found some bad moments on photos. I'll fix them. Sometimes only macro can show the quality of the work.Neo,
Looking good.
Hello,Mike! Thank you very much for the photo and comment! I think it will help me. Thanks again!Neo,
I went through my meager references on these early tanks. And in both sets of drawings (Bradford and Broughton) they show that bottom plate as being a smooth plate and with no bolt/rivets to hold it in place. But looking at the photo you have it appears there are some bolt holes along the top edge. So I would assume that the plate slots over the bottom lip and is bolted along the top lip. But then I came across this photo
FOR DISCUSSION ONLY.
Hope this helps.
Regards,
Mike.
Greetings, Colin! I suppose almost all I will do by myself :smiling5: I hope it will be interesting.You have a serious amount of after market goodies there, and it's already looking good at this stage.
Thanks again! Next week I will do this holders etc and then will go upper.Glad to see the info was of help Neo. A wonderful update as always. Keep it comin my friend
Thank you! Keep working!Fantastic detailing, keep up the great work Neo.
Yes,I think the rear is only the beginning of the long path.Neo,
Just cannot pick up a kit without adding more to it, I know the feeling well.
Mike.
Thank you, Steve! I think it is common to vehicles in Greece. Others in Europe has two lights.Not sure Neo. I have a look and see what I can find out. With the light being in the middle would there have been another one????
