Spitfire Mk.II (Revell 1/32)
Steven000
Steven
Belgium
Hi guys,
This 1/32 Spitfire is one of my 'shelf-queens', I stared building it a while ago and I would like to finish it as a 'new years' present for my dad (it wil replace that Fury-fish-tank-dio if you remember that one)
Here are some pictures of the build :
This week I added the canopy-parts with Micro Kristal Clear and masked them with Tamiya tape. I taped it off and used the raised surface detail as a guide for the knife.
Then I degreased the model with alcohol and sprayed a green tone on the canopy (interior color).
Then I sprayed black primer in all cavities and used white primer on the rest of the aircraft. I decided not to do a full preshading at this time...
I made a new wooden block for more project-sticks... Some parts I left off for easier painting.
So that's all for the moment, no time left this week to continue...
Thanks for reading and kind regards,
Steven
Was just looking at this and the IXc kits. Some people say it's rubbish and others love it. What do you think of it Steven?
Build is coming on great
Hi Alan, I had a few fitting problems with the flaps and ailerons, but I can't remember any details. Also I had to scrape the inside of the wing to get the assembled cockpit fitted... Further I think the front-glass-armor-canopy-plate should go more smooth over in the fuselage.
The decal for the instrument panel should be cut, in one piece it didn't overlap correct with the plastic panel. :thinking:
I got it for about 20eur (17£) so for that price I think it's a nice kit. :thumb2:
Cheers, Steven
That was my thinking point Steven. Both kits could be had for a grand total of £35 delivered and it would be nice to have some Allied aircraft in my stash lol
Hi guys,
Haven't got much bench-time lately but still a small update...
I masked off the propellers and sprayed the spinner and yellow tips.
(Weathering is for later)
The belly was sprayed in 'duck egg green', then masked off with Tamiya tape.
Then I sprayed the brown camo, I made a mistake by not spraying the whole model in brown, I think that would have helped to make the camo-colors matching better. :thinking:
I ordered some 'blu-tack' (grey), but I made the sausages to big so I had the use my blue putty too (more greasy)...
Because I made them too thick I had some problems on the masked lines, even in this scale it looked weird, (looked like 2 edges)
It can work if you spray very straight, but in the future I'll make the masking-sausages smaller to avoid this problem...
So in smaller steps this time I masked some areas off again, trying to fix these lines...
When it looked a bit better I masked and sprayed the black lines on the wings and the duck-egg-green-band (tail).
The black lines came out very sharp, I also lost the antenna-part on the rudder, haven't yet found it back :confused:
So that's all for the moment, next is a gloss coat and decals...
Thanks for reading and kind regards :thumb2:
Steven
You did that yesterday Steven? What a shame, you should have been at the NUTS! weekend at Bastogne :hungry::smiling5:. Just kidding. That masking turned out great, camouflage looks very good!
Looking really nice steven , cheers tony
Thanks guys,
Well I am almost there Wouter! :tears-of-joy:
We are in the car to Hardigny :smiling5::thumb2:
Cheers, Steven
Thanks guys :thumb2:
First of all, I found the lost aerial-thing in my trashcan, it was stuck in the masking tape :poop:...
This week I sprayed on a gloss coat, I used 'Mig lucky gloss varnish' for the first time, it seemed to work fine but you have to spray it in multiple, very thin layers, so it took a while.
These are the decals that come with the kit.
The red dots are separate decals, which I find a bit inconvenient to work with...
I used micro sol & set,
I always find it fascinating how the decals crumble and in the end adapt to the surface...
The underside has a raised part, so that's trouble to get the decal on there.
I couldn't help myself thinking about the young kid trying to get these on with nothing more than tap-water :sad-face: ...
After several applications of micro sol I was able to get it on very flat.
I got 2 crumbled lines in the decal though but because it's on the underside it won't be visible.
The rivets came through very nice I think!
The fuselage, again I did numerous passes of micro sol
I spend the whole yesterday-evening on the decals but I'm pretty happy how they turned out. :upside:
Next is another gloss coat to seal them in...
That's all, kind regards ; )
Steven
Looking very nice. Those decals have settled very nicely. It's nice to see the rivet detail on the fuselage side, not bad detail for the price.
I’ve never understood why the red centre dots are often separate on decal sheets these days. It only seems to make them more difficult to apply for the modeller — I suppose there’s a benefit to the manufacturer, but I fail to see what it is.
Is it a throw back to the days of frequently out of register decals ?
Coming together very nicely Steven. I'll defo be getting one of these now i've seen this build progressing
Wow, those decals sit ver nice in and around the details. Something which is hard to obtain with japanese thick decals and set and sol. I assume the revell ones are printed by cartograph?
Keep up the good work!
That would be more of a problem with the red/blue discs, I’d think, because you would probably get a dark line where the two colours overlap, and if so, then likely also a clear or white bit on the opposite side.
Thanks for the comments guys! :thumb2:
@Wouter : I don't know if they printed it via Cartograph, it says this on the bottom :
Since my last update I added a panel-line-wash (Tamiya black).
On the real plane the rivets might not be so visible, but I like to accentuate all the small details.
I broke off the landing struts and one aileron during the wash-cleaning :poop: ...
After the wash the model could dry for a few days...
Then I sprayed a few coats of Lucky Varnish (Ultra-Matt)...
After the varnish I sprayed the exhaust-stains, this should be more 'black-ish' for Allied aircraft as I learned here on the forum, but I liked the look of a dark-brown for this one.
I also added some chipping (aluminium paint)
I added a few colors to the exhaust-pipes to make them look more interesting, the wheels were painted too...
The aerial-wire was added with superglue (at the moment only on the rudder).
I used a thin plastic 'sewing thread' from the local warehouse.
I made a base again with MDF, I thought the oval shape had something Spitfire-ish :smiling6:.
The figure was stared a while ago, I used one of the Masterbox RAF pilots, which is probably the most used figure-box for all 1/32 spitfires :smiling5:...
I don't know anything about dogs, but I wanted to make it look more interesting then just plain-brown.
So I searched google for dogs and colors :smiling2: ...
Today I will continue on the base, aerial and canopy...
At the moment the model looks like this :
I wanted to make a grass-diorama, but because I'm running out of time (present for new-year) I glued a piece of sandpaper on the base (grey-primed), as a sort of runway... Will try to add some grass-tufts in the front ...
Thanks for reading and kind regards : D,
Steven
