Hi Simon you had your work cut out on this one but you've not knock it into shape as usual, great work yet again, keep up the magic.
Pete.
Pete.
Those two taken together make me wonder whether you put on the wrong arms? Very easy thing to do with these (ex-)Dragon kits that have unused duplicates of all sorts of parts.added all the suspension arms - for some reason I have eight spare ones :thinking:
None of the road wheels fitted onto the stub axles so I had to drill all the wheels out until they did
That's a good idea. Is that moulding putty 2 part stuff like rubber for resin?I have just mixed up some quick silicone moulding putty and pressed it on to one of the complete sections
Thanks Steven
Allen - you must have some very boring TV where you live! First look it appeared not too bad but the more I looked the more I found that needed work - cheers
Pete - thanks
Graeme - thanks
Bob - haha, nothing special just normal modelling stuff
a few bits added at the rear end
I then spent about two hours making the headlights - needed considerable fettling to remove flash and flared edges and to get the etch to fit
used Grandt Line wing nuts rather than the wafer thin etch ones
Also cleaned up the rest of the suspension arms and made a start on the dampers
The damper tubes are badly moulded with a huge step between front and back - if I clean them up to get rid of the step this will result in the tubes being way too thin
I will therefore replace the dampers - the top and bottom mounts cleaned up ok so I only need to replace the tube part
