This is turning out to be a real battle, the flap & outer wing sections have has their PE fitted - not without a lot of filing, and cursing. Despite me cutting the wings as accurately as I could, I still needed a lot of fettling to get any sort of fit!
It was also one of those days that the CA didn't want to stick......................
The major problem is the stub wings. I added the PE wheel well walls - bad move! It would be better to scratch some plastic parts instead. The PE walls are too large - the instructions say that some plastic will need to be removed to get a good fit. A minor understatement! I have had several attempts to get the wings to fit over the PE, but no go. I'm thinking that I'll have to remove the PE, and ditch the wheel well detail altogether. You will only be able to see this if you pick the model up, so I think I can live with that
