Ouch! That’s going to smart colin . One thing I can think to solve this without breaking it all apart again is drill all the way through the centre of the wheel ,from both sides , where the circular depression is at the bottom of the oleo leg. Hopefully this will allow the wheel to come free then you can swap them and use a piece of brass or steel rod through the drilled hole to fix them again . Hope you can sort it , it’s looking beautiful , cheers tonyCan you see that nicely moulded flat in the tyre, see how it slopes from left down to the right ? Well it's wrong, it should slope the other way, right to left. The other wheel is wrong as well. (insert big string of naughty words here)
