Great attention to detail Chris, nerves of steel with those p.e and resin parts.
Thanks
Vaughan! I learned a long time ago that I have a threshold for repetitive, fine work, and this one has been putting that to the test!
I thought I was finished with the last round of updates, but I found a PE antenna that need to be added and needed to make a pitot from stretched sprue.
While I was doing that I considered the nav lights. Generally I would just paint them, but I have been curious about using clear sprue so I decided now was the time.
I removed the plastic nav lights from the wings and I dug out the left over clear sprue from my Tamiya Spitfire and began fashioning with my flat needle file.
Once I had a broad profile that crucially was square and fitted well, I separated two pieces and drilled holes in the rear end. These were then filled with red and green paint.
I painted the cut and cleaned tips of the wings and gave the faces a coat of bright aluminium paint before CA'ing the new nav lights in place.
I then set about matching them to the profile of the wing, again with my flat needle file.
Once I was happy with these I polished with wet 1000 grit. I was skeptical about the toothpaste polishing method but gave it a go anyway. I am now convinced it works! No more scratched canopies on my builds! Ahem...
Complete with antennae and pitot.
The next step really is final degrease and primer!
Cheers.
