Daddy, The Swinging Suburbanite! By Testors
Daddy is Drag Hags other half and he's rushing home from the office to see her .
Box Art.
Parts
Love these instructions.
Thank you.
Hope everyone is safe and well.
Pete.
Hi got some bits built on this one.
Front and rear wheels all made up, added centre caps and tyre valves.
Built up one side of the diff with punched out discs from white card and added filler plug and drain plug.
Before and after on the hand there's a lot of flash as you can see.
Have used ships air funnels from my my spare scrap box how to make air manifold intakes and exhaust pipes all cleaned up and cut them fitted.
Added prop shaft, chassis rails and handles to the side of the coffin.
Mock up only.
Assemble the hat and the head I will have to build up the rear of the mouth because it's too open.
Thank everyone for looking in
Pete.
A bit more messing about made up some big spark plugs and distributor cap and leads.
Thank you very much for looking in.
Pete.
Hi Pete
That I can well understand - always need to get home to the little woman after a hard day at work.
Nice additions already.
Off to a roaring start Pete! Your imagination and resourcefulness are beyond words!
Rick H.
Hi Pete
Hi Jim thanks for looking in getting there slowly as always.
Pete.
Rick H.
Hi Rick I can think of a couple and I bet there's a few other people on here that can as well.
Pete.
Great start pete and a fitting partner for the Hag!, cheers tony
Very small update too busy eating Easter eggs.
Fitted distributor cap and leads and made up coil.
Adding buttons to shirt slaves.Added hinges and catches also personalised it
Back to some more eggs.
Pete.
