It's an old shed out the back, I'd rather we had it than didn't.Beautiful, although For your sake I hope it doesn’t decide to set up home, we had all sorts of problems when they set up home in the village church, lots of problems with maintenance because you cannot disturb the roost.
if you don’t need the shed then it would be brilliant to have them stay,It's an old shed out the back, I'd rather we had it than didn't.
We have lots of the little pipistrelle, not seen these Brown long-eared ones before.
Brown Long-Eared Bat - Protected in the UK under the Wildlife and Countryside Act, 1981. Priority Species under the UK Post-2010 Biodiversity Framework. European Protected Species under Annex IV of the European Habitats Directive.
Probably just out of hibernation.............
Which translated into normal speech means; You cannot do anything to the building if it disturbs it. We had t get a bat survey done to have our extension built. £200 for a 10 minute check!
